ECU reset
Prispevkov: 6837
Alfa Romeo GT 2.0 JTS 2006
Zakaj, saj v osnovi je to od 75-ke.
dzuko
Prispevkov: 697
Vpliva to kaj na "čipiranost"?
pero666
Prispevkov: 1445
Vozilo: 166 3.0 V6 & 159 TI
po logiki naj ne bi, saj ne brises mape, apmak samo priucene podatke. Je pa podoben postopek za bencinarje. Novejsim lahko sicer te priucene podatke zbrises z examinerjem.
Prispevkov: 9758
vpliva samo da avtomatsko kalibracijo motorja...
alfa 166
Prispevkov: 510
Pridružen: Če Jul 29, 2004 2:34 pm
Kraj: ljubljana
A ta reset ecu ja deluja na 2.4 mjet?
Prispevkov: 9758
Naj bi...
alfa 166
Prispevkov: 510
Kraj: ljubljana
kaj pa ta metoda?
HOW TO: ECU & Throttle Reset
by thkc » Wed Oct 04, 2006 12:17 pm
Some methods which you can use to reset your ECU & throttle:
Using the Examiner to reset your ECU
Get your mechanic to use the Examiner to reset your ECU (unless of course you have one at home lar)
Start the engine but do not touch the throttle and let the car idle for 15 mins otherwise the car will not rev freely afterwards
Turn the car off and leave for 10 mins
Start the car and take her for a blast
Manual process
Disconnect the negative lead from the battery for a minimum of 45 minutes. Some people recommend overnight but that is not really necessary.
Reconnect the battery negative lead
Put key in ignition, turn to MAR and leave for 90 secs
Turn off the ignition, but not remove the key and leave for 90 secs
Start the engine but do not touch the throttle and let the car idle for 15 mins otherwise the car will not rev freely afterwards (as V6 owners know at their peril)
Note:
Blue = ECU Reset
Orange = Throttle reset
For the more impatient folks:
For step 1, disconnect cables from battery and just apply a wire across the positive and negative wires (NOT on the battery!) to clear any residual memory/charge - you don't then need to wait 45 mins!
Note: Please add on if you think something's amiss fear does not exist anywhere except in the mind
thkc
Ex-Committee
ICQYIM
juri.erdeljc
Prispevkov: 72
Pridružen: Če Nov 27, 2008 3:02 pm
Dräger napisal/-a:Na alfaowner sem zasledil tale napotek.Je kdo že probal na svojem avtu?
1. Disconnect battery for 45 mins
2. Reconnect battery, and turn ignition to MAR for 90 secs
3. Turn off and leave 90 secs
4. Start engine WITHOUT pressing throttle and let the car idle for 15 mins (I repeat, do not touch the throttle whilst the car is idling)
5. Turn engine off and leave for 10 minutes
6. Start the car and go for a drive, using a number of styles (eg town, motorway, thrash etc)
mene pa mal zanima glede tega ecu-ja, k se glih ne spoznam na to preveč (vem pač da je to rač. ki računa koliko bencina, zraka in ostalih stvari ubrizgava). 6.točka mi ni najbol jasna, a po ga pol peleš po različnih terenih oz cestah na polno al normalno vožnjo? :)
kosir1234
Prispevkov: 3687
Kaj naj bi sploh pridobil pri tem resetu?
Prispevkov: 6837
Če je vse prav, potem nič.
Jaz sicer ta postopek uporabljam, ko odklopim akumulator.
Uporabno je tudi v primerih, da se zamenja kak problematičen del (MAF, lambda, ...), da se ECU hitreje nauči delat s pravimi podatki.
PS
Ne preveč komplicirat s tisto vožnjo, jaz se velikokrat sploh nisem nikamor peljal, ampak samo ugasnil, naslednje jutro pa se normalno odpeljal v službo.
simnov
Prispevkov: 780
2006 120KM
Ah rajši ne ,da ne bo cukala :mrgreen:
