Zamenjal sem jo z novo in ko sem prižgal, sem opazil, da je ostal v low poziciji. Pogledal sem motorček za nivo snopa in dela normalno: gre ven in nato nazaj.
Poizkušal sem ročno nastavitev in seveda sem pobral plastični vijak do kraja.
OK, I have eventualy figured this one out. It's actually quite simple to refit the ball of the level adjusting motors into the retaining keyhole of the housing.
The first thing you need to do is find the main beem connector at the back of the light housing. If you wiggle it, you will see that the whole of the rear of the light reflector (high beem and HID) wiggle too. You will also notice that the keyhole for the motor ball slides in and out.
Press down until the keyhole slides almost to the end of its travel (towards the ball/engine). At this point push the ball into the keyhole with a slight upward action, you should feel it grip. Let go of the high beem connector and fully engage the motor.
