Stran 1 od 1
2 DIN radio - AR 156
Objavljeno: So Jan 23, 2010 12:08 pm
Napisal/-a _doog_
Objavljeno: So Jan 23, 2010 12:37 pm
Napisal/-a GS
Res hudo zgleda...
Objavljeno: So Jan 23, 2010 12:56 pm
Napisal/-a _doog_
Vem. Bomo probal kj ustvart..
bom najdu s kšne razbite armaturo....
Objavljeno: Ne Jan 24, 2010 1:39 pm
Napisal/-a MaStr
Takole zgleda v moji 159-ki:
Je pa pri 156-ki potreben malo večji poseg, ker moraš enoto za klimo prestaviti stopnjo nižje.
Objavljeno: Ne Jan 24, 2010 8:10 pm
Napisal/-a _doog_
Zelo lepo
Kako si pa ozadje prštimu
Objavljeno: Po Jan 25, 2010 1:54 am
Napisal/-a MaStr
Obstaja opcija shranitve ene slikce...
Objavljeno: Ne Dec 12, 2010 10:14 pm
Napisal/-a MrPetek
Si se že lotil tega projekta?
Objavljeno: Ne Dec 12, 2010 10:18 pm
Napisal/-a lizard
V 159-ki zgleda v redu, v 156-ki pa ni za nikamor.
Objavljeno: Ne Dec 12, 2010 11:09 pm
Napisal/-a _doog_
Na fl armaturki je men kr ušeč
Jst se nism še lotu tega, kjer nism se dobu nobene pocen konzole take cene so mi prbijal joj
Re: 2-din v 156
Objavljeno: Po Jan 09, 2017 4:47 pm
Napisal/-a Peter27
hello my name is peter 27 and I've just joined your club in slovenija also the reason I was looking who miss a two din car radio built didst in facelift Alfa Romeo 156 because in the Netherlands there is nothing to get from so I went searching on the forum and saw you standing photo doog in slovenija and so I can send a message to you because I would like to make the same as you've made in your alfa Romeo 156 now I sit with a problem that is the bottom of the dashboard with the metal strip in the dashboard where the heater operating normally on stuck because it was a 2 din car is 7 inches Kenwood must all things now I know how it all up in the dashboard does that the problem is not but I'm on the bottom that metal strip in the dashboard and would like to know from you doog how you've done that with the heater operation and hope that the mine can can make out empty or a drawing how exactly have I done saw that they had the heater panel had done down made in the console or the clocks down into the console in building but I thought of you have I made the most is my email address there to put as you my e mail I will send pictures to do it because I think it does not go through the forum can send along so I thank you may peter 27 email
peterbravenboer@hetnet.nl
Re: 2-din v 156
Objavljeno: To Jan 10, 2017 8:09 am
Napisal/-a Binji
Peter please type using punctuation marks otherwise it is VERY hard to understand what you are saying.
Doog did not make this modification as he was writing his post, he just created a preview of how it could look like.
Re: 2-din v 156. Aks peter 27
Objavljeno: Ne Jan 29, 2017 3:03 pm
Napisal/-a Peter27
zdravo doog Imam vprašanje o facelift Alfa Romeo 156 bj 2004 I zgradili v armaturno ploščo imam vprašanje o kovinskem traku na dnu, kjer je kontrola grelec pride, da ste pritrjen kovinski trak nižje dol in konzole prestregla vrh, kot če vas moj blagoslov, ki bi lahko, bi jo cenili, kako si to hvala peter 27
Peterbravenboer@hetnet.nl
