Renault Laguna GT
Gorkichev
Prispevkov: 1818
Enen redkih renaultov ki me prepriča. =D> :D
4 kolesno krmiljenje ki ga sploh ne razumem. kako je možno da se zadnje kolesa nad 60km/h obračajo v isto smer kot sprednja - sploh zavije kaj :? :lol:
še en zanimiv poslentek - Renault Laguna GT vs Porsche Boxter S http://youtube.com/watch?v=QaTnd3ozcaE
Pepsi
Prispevkov: 5161
Za svoj odgovor bom uporabil kr dva komentarja ki sta bila pod filmčkom:
where do you get this things from dude...
Porsche Boxter S is a s**** anyway
:lol: :lol: :lol:
Sistem pa deluje na istem principu kot na zadnjih Preludkah... Tole je opis Renaultovega sistema:
At low speeds, the clever system is designed to boost manoeuvrability, so below 37mph the rear wheels turn in the opposite direction to those at the front. They can only rotate by 3.5 degrees, although that’s still enough to cut the standard Laguna’s turning circle from 12.05 metres to 10.80 metres.
Pri visokih hitrostih pa tako kot si omenil:
Above 37mph, the rear wheels are programmed to turn in the same direction as those at the front, to boost stability and road holding. At these speeds, the rear axle permits only two degrees of turn, while the maximum turn angle of 3.5 degrees is available only during emergency situations.
It’s at higher speeds that the set-up really impresses, though. There’s more feel than in the regular model, and the Active Drive chassis is extremely effective at controlling body roll.
Ozi
Prispevkov: 3611
Kraj: Rivercity
Zelo dobro =D> to ima podobno Nissan Skyline GT-R - sistemu se reče Super-HICAS four-wheel steering :wink:
Kakšen je pa motor?
Creed
Prispevkov: 4301
A nima tak sistem tud Citroen Xsara? :? Drgac pa presenetljivo. Kmalu bodo...praqvzaprav so ze "family saloon" avteki hitrejsi kot sportniki ala Porsche in podobno :lol:
Miholl
Prispevkov: 5328
Vozilo: 156 sw
Čičal v njej sredi Pariza....res hud Reno... (glede na to da je Reno)
Uroš
Prispevkov: 3652
Kraj: Maribor-Tezno
Saj res da ima vsako oko svojega malara, ampak nova Laguna je pa tako ekstremno grda da malar oslepi !
Pravi prvi avto za slovenceljna, drugi pa Golf.
Uroš
Teo
Prispevkov: 9750
Kraj: Slovenska Bistrica
To pa res, jaz ko sme jo prvič videl, sem mislil, da so se zmotili. Sedaj ko so naredili pri Mercedesu še GLKja vidim, da s etrend odurno grdih avtomobilov nadaljuje.
dejch79
Prispevkov: 196
Pridružen: Po Sep 17, 2007 11:02 pm
No jaz sem vozil novo Laguno 2.0 dci. Imel testno en dan.
Avto je kot ste omenili, grd,resnično grd. Tako da sem se večinoma z njo vozil samo ponoči :lol:
Ampak notri se ne sedi slabo, tudi vožnja ni tako slaba. Le nekako nervozen avto se mi je zdel.
No kar se pa tiče oblik novih avtomobilov. Super če bodo nadaljevali v taki obliki. Bomo vsaj Alfisti ne cesti požemali več obračajočih se glav za nami :)
Gorkichev
Prispevkov: 1818
Uroš napisal/-a:Saj res da ima vsako oko svojega malara, ampak nova Laguna je pa tako ekstremno grda da malar oslepi !
ja....tudi mene ni nevem kako ušeč. sej sprdni del ni napačen, ampak rit je pa obupna. v tej različici (sport gt al kako je že) pa mi slpoh ne zgleda napačna. bol kot zunanjost pa me prepriča notranjost. sedi se zelo dobro, armaturna pa deluje precej inovativno
Pepsi
Prispevkov: 5161
Edini Renault vreden mojega denarja:
Klik
Jonny
Prispevkov: 489
Pridružen: Ne Mar 25, 2007 10:34 pm
Kraj: Bled
Gorkichev napisal/-a:
Se strinjam da je grda ma fotr navadno 2.0 dci. Sprednje luči bodo kmalu do brisalcev gor potegnili #-o zadaj je preveč visoka, notranjost no ja sedeži (vsaj zame) niso udobni pretrdi, volan je pretenek :) se moreš mal matrat da ga z eno roko "motaš", pr menjalniku moreš malo paziti ko daš v 6. da ti ne gre po nesreči u 4. Ima pa zlo dobre bremze 8) samo pobožaš pedalo pa se že ustaviš.
Dejch
Prispevkov: 2225
Vozilo: Avant2Go
Teo napisal/-a:To pa res, jaz ko sme jo prvič videl, sem mislil, da so se zmotili. Sedaj ko so naredili pri Mercedesu še GLKja vidim, da s etrend odurno grdih avtomobilov nadaljuje.
Meni pa Laguna nikakor ni grd avto, ok zadk bi lahko bil malce bol zakljucen, ampak nasplosno ni slab avto, ni pac povprečen in na prvi pogled prjazn. Seveda ni kakor Laguna coupe concept, ampak dalec od grdega avtomobila kot npr. Megane ali Vel satis. Ce bi kupovat avto tega razreda in da je nov, bi meni osebno bil kar problem med Laguno, Mazdo 6 in Alfo 159.
