Odpoved sistema ASR, VDC,... - AR 156 /147/ GT
Re: Odpoved sistema ASR, VDC,... - AR 156 /147/ GT
OdgovorNapisal/-a RaceBoy » Ne Apr 01, 2018 12:24 pm
...hm..sej nevem kolko ma to veze. ma sm precital na angleskem forumu.
We had this problem repeatedly when our 147 was new, apparently it is very common and usually associated with the brake light switch, I don't know if it was replaced or adjusted but it has never re-failed in the last 3 1/2 years. I was told that it is due to the fact it has two contacts within it and if they are not perfectly syncronised a 'mismatch' error is generated and the system spits it's dummy out.
RaceBoy
Vozilo: Alfa GT Q2
Prispevkov: 167
Pridružen: Sr Sep 26, 2007 2:01 pm
Kraj: Brkini
OdgovorNapisal/-a archie » Sr Apr 11, 2018 2:36 pm
Danes sem šel poizkusit na mokro travo....Rezultat, Alfica umazana, kakor bi vozil motokross.
Pri vklopljenem ASR ( obkrožena modro ), mi lučka za VDC (obkrožena zeleno ) utripa in odvzame plin, cca 2000 rpm, pri izklopljenem ASR, pa plina ne odvzame. Nikoli pa mi ne utripa lučka ASR !
A je to pravilno delovanje ?
Centrala je Bosch ABS 8 VDC, ISO Code :25 86 20 04 A4
archie
Vozilo: Alfa GT 1.9 16V JTD M-Jet (150 Hp) letnik 2009
Prispevkov: 12
Pridružen: To Mar 20, 2018 11:12 am
Kraj: Metlika
OdgovorNapisal/-a moofdi » Sr Apr 11, 2018 6:15 pm
Ja se če izklopiš asr je normalno da ne odvzame plina...asr = traction control. Se pravi če je vklopljen preprečuje vrtenje v prazno tako da odvzame gas, če ga izklopiš potem pač elektronika ne posega vmes.
Vdc je pa esp, tega se pa tako ne da izklopit.
Pomoje zadeva deluje pravilno.
Vozilo: 156SW 2.0TS, 155 24V V6, R19 16V
Prispevkov: 1537
Pridružen: Pe Maj 09, 2008 1:53 pm
OdgovorNapisal/-a archie » Ne Apr 15, 2018 2:03 pm
Moti me, ker piše v navodilih, da ASR lučka utripa, kadar je sistem aktiviran ( zdrsavanje )
Enako piše tudi za VDC lučka utripa, kadar je sistem aktiviran.
Meni pa utripa samo VDC, ASR nikoli ?
archie
Prispevkov: 12
Kraj: Metlika
OdgovorNapisal/-a archie » Po Mar 25, 2019 11:18 am
Pozdravljeni spet !
Preko vmesnika ELM 327 sem poizkusil narediti nekaj meritev, pa mi ne kaže vzdolžnega pospeška.
A je kriv vmesnik ali kaj drugega?
Vmesnik
Meritve
archie
Prispevkov: 12
Kraj: Metlika
OdgovorNapisal/-a RaceBoy » To Apr 30, 2019 4:44 pm
Zivjo.
Ne najdem ali pa ne znam :) v forumu ce je kje tema z napako p2015. namrec pri gt 1.9 jtd se mi je uzgala lucka motorja in z obd sem prebral tole napako. nekaj sem cital po googlu, da naj nebi odpiralo oz premikalo sesalnih loput ? hvala
peter
RaceBoy
Vozilo: Alfa GT Q2
Prispevkov: 167
Kraj: Brkini
OdgovorNapisal/-a TribesMan » To Apr 30, 2019 8:37 pm
Težava s servo motorjem ali napeljavo okoli swirl loput.
Vozilo: Something else
Prispevkov: 9640
OdgovorNapisal/-a RaceBoy » Pe Jun 07, 2019 2:43 pm
Skratka. Za to napako P2015 sem peljal k mehaniku je resetiral in je rekel, da ni videl nobenih anomalij....danes zjutraj. paf...avtovleka... klice mehanik, da je strgalo zobati jermen ! kot je videl na hitro naj bi zaribal napenjalc. Kaj ima ta napaka kej veze s tem ? Da so se ze prej zaceli kaki simptomi glede jermena ? hvala
RaceBoy
Vozilo: Alfa GT Q2
Prispevkov: 167
Kraj: Brkini
OdgovorNapisal/-a TribesMan » Pe Jun 07, 2019 2:45 pm
Ne, ta napaka ni povezana z jermenom...
Prispevkov: 9640
OdgovorNapisal/-a RaceBoy » Pe Jun 07, 2019 3:07 pm
Super. Se pravi se vec pizdarij:) Kaj ce utrze zobati jermen naredi veliko skode ? Ali se polomijo samo klikerji na ventilih ? vem sem optimisticen :)
RaceBoy
Vozilo: Alfa GT Q2
Prispevkov: 167
Kraj: Brkini
Prejšnja
Vrni se na 156, 147, GT
Po forumu brska: 0 registriranih uporabnikov in 3 gostov
