Faceliftane 159, brere in spiderji bodo lažji
Teo
Prispevkov: 9750
Kraj: Slovenska Bistrica
1.9 JTD TT se že prodaja in tudi v revijah je že polno testov novih 93jev s tem motorjem, tako da verjetno res ne bo dolgo, ko bo ta motor prišel tudi v 159, kakor je bilo uradno napovedano.
In po testih 93 zelo zelo gre s tem motorjem.
Gorkichev
Prispevkov: 1818
tehnični podatki za saab 93 1.9TTiD, 132kW (180PS)
Zylinder/Ventile
4/4
Hubraum
1,910 cm3
Nennleistung (EU)
132 kW (180 PS)
Max. Drehmoment (Nm bei U/min)
400 bei 1850-2750 (MT6); 370 bei 1750-3250 (AT6)
Höchstgeschwindigkeit
225 km/h; Automatik: 220 km/h
Beschleunigung 0-100 km/h (6-Gang)
8,5 Sek./ Automatik: 8,9 Sek.
Elastizität
60 - 100 km/h im 4. Gang: 6,0 Sek.
Elastizität
80 - 120 km/h im 5. Gang: 7,9 Sek.
Kraftstoffverbrauch l/100 km* (Kombinierter Verkehr)
5,9; Automatik: 6,7
luni
Prispevkov: 617
Pridružen: To Feb 21, 2006 1:35 pm
Kraj: Maribor
Vrnimo se na temo.
Alfa Unica Kit�available with the launch of MY08 (debut in december)
1.9JTDm 150hp--> 170hp
3.2JTS 260hp--> around 300hp (with the add of turbo)
159 Crosswagon will propably debut in Geneva.
The production of 159my2008 begins in 6 november.It will weight around 90kg less and the SW version -100kg..1.8/1.9JTS/2.2JTS will be replaced in first termister of 2008 with 2 versions of 1.8�at 160 and 200hp�.in second semister of 2008 we will se the 230hp version of 1.8.
The new 3.0jtdm v6 is currently tested in two versions�270hp/560nm and 306hp/600nm.We will see the new 2.0 multijet earlier than it was scheduled�..the new 2.0 multijet in it�s TST version has a an output of 210hp/420nm.
1.9JTD TST press release
http://www.fptpowertrain.com/eng/pdf/Comunicato_uk.pdf
2.0JTD TST will be the first diesel engine of the Groupo to adopt multijet 2.It will be exclusively available to Fiat Group Automobiles.It will propably debut in June of 2008.Until now it has an output of 210hp/420nm.
http://www.fptpowertrain.com/ita/img_en ... rbo_1b.jpg
http://www.fptpowertrain.com/ita/img_en ... rbo_1w.jpg
Tko vidi lice ninđe, umreće u strašnim mukama!
caka
Prispevkov: 52
Pridružen: Po Jun 06, 2005 1:32 pm
Od uradnega prodajalca info, model 2008 na zunaj nič sprememb, bo pa nekaj ostalih sprememb, kaj več informacij pa nimam (ali bo to kaj sprememb v notranjosti - očitno).
luni
Prispevkov: 617
Kraj: Maribor
159 & Brera/Spider MY2008
-80-90kg less
-Suspension upgrade
-New wheel designs,exterior colour palette,interior trim��the trunk will open automatically by pushing the AR badge.
-A Front Wheel Drive version with the 3.2JTS will be available.
-1.8T 230hp�presentanion in June or October/2008
-1.9JTDm TwinStage 190hp��June/2008
-All current diesel engines will be upgrated.
-Unica Kit for 1.9JTDm and 3.2JTS.
159 MY2008:Market Launch � 3/3/2008..available with the new 1.8JTB 200hp/320NM
159 1.8JTB 265hp/400nm (launch in 2009)�simiral anperformances with 330i and price with 325i.
Gorkichev
Prispevkov: 1818
če je to res.... €€€$$$$$$ na kup in hitro naročit 1.8T (200KM) z opremo TI.
...rdeća, krom ogledala :P :-({|= 8) ......... Q2
Bearex
Prispevkov: 2223
Pridružen: Ne Feb 04, 2007 10:32 pm
Kraj: Štore
$$$ zdej rajš pršpari, ker niso kaj preveč vredni :lol: :lol: :lol:
A drugo leto pol ne bo več možno kupit nobene 159 ki bo mela manj kot 130kW?
To bo pomojem zlo slabo vplivalo na število kupcev... sploh tistih z malo tanjšimi denarnicami. Kdo pa ma 1500€ za registracijo...
alro
Prispevkov: 2700
:lol: ta je pa dobra. Verjetno tisti ki bo mel za novo 159, bo imel tudi za registracijo, čeprav je res da je večina 159 (vsaj v slo) z motorji 1.9 (110kW).
Alfista
Prispevkov: 2069
Kraj: Brda
TribesMan napisal/-a:A drugo leto pol ne bo več možno kupit nobene 159 ki bo mela manj kot 130kW?
Brez skrbi! Kar jaz vem, ostajajo 1.9 tudi v 120 in 150 konjski različici v prodaji! Pa tudi 1.8, 1.9 in 2.2! Za zadnjega sicer ne vem, ker bo zelo blizu 185 vs.200konjev.
Ciao Alfista :mrgreen:
120KM JTDja mislim da že dons ne moreš več kupit. Vsaj v Sloveniji ne.
Poleg tega v tisti napovedi piše "-All current diesel engines will be upgraded."
1.8 bencinarja tud ne dobiš v Sloveniji. Torej ostanejo 1.9JTS, 2.2JTS (če bo ostal), 1.8JTB in 3.2JTS... Ter 1.9JTDm, 1,9 JTDm TT, 2.4JTDm, (2.4JTDm TT??)
Dva motorja pod 130kW, noben pod 100kW.
Bjorn
Prispevkov: 1340
Pridružen: So Avg 26, 2006 2:17 pm
1.7 tone težek avto enostavno ne more imeti motor z manj kot 100kw, sploh pa znamka z sloganom cuoro sportivo.
1.7 tone ima 3.2 Q4 al pa 2.4JTDm... 1.9JTS ima 1.5 tone, in že ta ima 107KM/ tono... ne moremo rečt da je to malo.
Pa glede na to da obljubljajo znižanje teže, se bo to razmerje moč/teža še povečalo.
Sej nimam nič proti če obstajajo močnejše različice, je pa dobro imeti tud kakšno "razumno" verzijo.
Gorkichev
Prispevkov: 1818
mene se zdi neumno dat 30k € za avto ki ima manj KM kot ena stara 155 ki je 250 kg lažja.
1,5t z manj ku 100 kw delaš kolono :oops:
če že daš 30k € nabaviš strup. in če že govorimo o takem dnarju mislim da ni panike dat usako leto 1500€ za spravit avto na cesto....če že pomisliš da zgubiš v 1letu 20% vrednosti avta
če zdej malo gledam.... 2.2 jts ima 1490kg. -80 kg -> 1410 .....1,8T (200KM) - to bo pravo....pa še tuning potencial 8)
alfafil
Prispevkov: 4576
Kraj: maribor
-namesto da povečujejo moč,bi bilo boljše da zmanjšujejo težo,oziroma,naj pustijo bazne modele,saj jih ima konkurenca tudi :wink:
-in 159 JTDm 120,se prav spodobno pelje,kakšne kolone neki,ne bluzi če nisi probal :doubt:
