Kaj ko bi se ti učil mogočeopankar napisal/-a:Sem videl, da jih ima tudi Fiorano gor, tako da zanič ravno niso.![]()
So naročene, v četrtek bodo verjetno že na avtu, pol pa stestirat.
imel na moji, dimenzije 205/45/16 - KATASTROOFA OD GUME (usaj če jo primirjam z p zero neroandreiro_21 napisal/-a:A ma kdo kakšne izkušnje z gumami BF goodrich
Ja, vpisanih imam cel kup. Sprasujem pa ravno zaradi tocnega kazanja stevca. Ce imas malo manjso/vecjo gumo, so potem malenkostna odstopanja.Creed napisal/-a: @kixs
Ce sta obe vpisane, pol sta obe praveOsebno pa bi raje izbral 195/50r15.
Po 500 prevoženih km so se P7 očitno utekle. Oprijem se je precej izboljšal tako na suhem kot po mokrem, tud glasne niso več tok.žival napisal/-a:V torek na mamin avto montiru pirelli p7 v dimenziji 195 65 15 in lahko samo rečem, da sem izredno razočaran. Po mokrem precej hitr zdrsne, na suhem niso nč posebnega, glasne pa tok k bi ble 10 let stare. Ni mi jasno kako je ta guma zmagovalka testa.
Enako nevarno je celo gumo posprejat, da se lepo sveti!Running in your new tyres
It may sound like an odd concept, but if you buy brand new tyres and slap them on your car, then try to drive the nuts off it, you're going to come a cropper. The reason, believe it or not, is that all tyres need a running-in (or scrubbing-in) period. When tyres are made, they're typically injection-moulded in a heat press. In order to get the tyres out of the mould, it is first lined with a non-stick coating. When the tyres pop out, some of that releasing agent sticks to the tyres themselves. What you get is a nice shiny new tyre, with 'shiny' being the operative word. The releasing agent can take as much as 500 miles to scrub off. Now for the everyday Joe, this isn't really so much of an issue, but for people who are fast drivers, or think they're fast drivers, this can lead to a distressing loss-of-grip mid-corner and a visit to something large and solid. It's doubly important for motorcyclists because they have half the number of tyres and a much smaller contact patch per tyre to boot.
500 miles = 804.67200 kilometerkixs napisal/-a:Gume potrebujejo cca 500km da se vnesejo. Predvsem, da se znuca zgornja plast.
Bolj natancen opis:
...as much as 500 miles to scrub off...
AS MUCH AS 500 = tudi do 800kmOzi napisal/-a:500 miles = 804.67200 kilometerkixs napisal/-a:Gume potrebujejo cca 500km da se vnesejo. Predvsem, da se znuca zgornja plast.
Bolj natancen opis:
