Poznate posameznika ali firmo ki opravlja ultrazvočno čiščenje. Pacient: sesalni kolektor na jtd mašini.
Zapacan do amena...
Za informacije se priporočam.
hmmm....brener še imam od polaganja izolacijeEl Barto napisal/-a:Ammmm ...![]()
http://www.youtube.com/watch?v=oet4qWeZuYA
Tale ma pa še dobro glasbeno podlago:![]()
http://www.youtube.com/watch?v=reJmZQwR ... re=related
Sicer pa dvomim, da bo W5 imel kaj možnosti proti svinjariji od dizelašev, ki šibajo auspuh v sesalni kolektor.
Torej demontaža in ultrazvok ali dobra mehanska obdelava.
Ja...sem pomislil da bi to rešil s sesanjem iz kolektorja; imam namreč Kercherjev sesalec (rostfrei izvedbo) in sesalna cev "paše not v kolektor". Večje trde delce bi tako posesal.Overs[t]eer napisal/-a:Če čistiš, potem razdri tako kot se zagre. Na hrvaškem forumu se je nekdo na tvoj način lotu tega in rezultat - eden izmed trdih sajastih delcev je po vžigu šel naprej proti motorju se zataknil na sesalnem ventilu, ki se posledično ni mogel do konca zapreti - mu je skrivilo en ventil in uničilo vse kar spada zraven.
Quote:
Hey guys, I've got a 98 1.8T. I've had a k04 and chip for a while and wanted to get more performance. I was recommended to port and polish the intake and exhaust. We found out they used abrasive material to do it like gritty sand. So I got with my friend that tunes Hondas and we decided to try it ourselves. We got a bag of sandblasting sand and hooked up into the intake and started the car. We had to hold the gas so it would run. He wanted to let the engine suck in the sand through the intake so it would port it out and then push it out the ehxaust so it would port the exhaust manifold.
I was worried that it might cause problems but he figured it'd be OK as long as we didn't make boost and it get sucked in the turbo. After running the car and letting it suck in sand we got about half way through a 25 lb bag. The check engine light was on and the engine was bucking and kicking and sounding really weird. We stopped and hooked the car back up normal and took off the sand supply. We tried to start it again and it was really hard. Once started it couldn't idle and kept making weird noises. We took it out and drove it and it started to make scraping and knocking noises.
Help! Can anyone tell me what to do! My buddy only does Hondas so he doesn't know much about Audis.
Imam wapa z dizel grelcem; se pravi enih 100 stopinj pa bo.Crazy Alfista napisal/-a:wap bo ocistil vec kot dovolj, sem cistil kolektor an audiju a3 in je slo vse stran
