Ali kdo pozna to Alfo - 8
Zaklenjeno
alcantara = umetno brušeno usnje
http://www.winter.si/index.php/umetno_bruseno_usnje/
get over it!
Dräger
Prispevkov: 2454
Type III - Cleaning Alcantara® Leather
Alcantara® Ultra suede™, Ecsaine, Micro suede, etc) are not types of leather but are in fact in synthetic materials, it is made from extremely fine polyester microfibers (68% polyester and 32% urethane) it has the appearance and tactile feel similar to that of suede, and it may be incorrectly identified as such. Toray Industries' Ultra suede or Alcantara is finding application in seating as well as dash trimming, steering wheel covering and headliners in many high-end OEM automotive applications
Identifying characteristics - these materials are very soft to the touch and will scratch or scuff very easily.
The water-drop absorbency test- water drops will darken the surface and will remain dark or leave a water mark after drying.
Water absorbency rate – high, due to the potential damage caused by water foam cleaners are highly recommended
Well known for its use in top marque automobiles such as Aston Martin, BMW and Ferrari, this material is both hard wearing, luxurious and stylish. Suede is rarely used for automobile upholstery, however Nubuck or a synthetic known as Alcantara® Ultra suede™ is commonly found in sports luxury vehicles; on the steering wheel, armrests and seat inserts both for aesthetic purposes and grip (on the seats and steering wheel) and the headliner, it is highly absorbent, creating a texture similar to velvet, many people confuse this product with suede leather.
As a general rule when cleaning Nubuck, Alcantara ®, Ultra suede™, Ecsaine, Micro suede, etc you should only to use products specifically designed for this type of fabric. Avoid using a product designed for cleaning leather. It's also important to do a patch test before cleaning any fabric to make sure the colour or integrity of the fabric won't be damaged. To do this, apply your cleaning product to an inconspicuous area to see what the effect will be.
Use a napping brush to raise the pile and loosen / separate the fibres. Remove pilling with a single-sided razor blade and then apply a suitable cleaning solution on to an applicator pad and apply to one area at a time (do not over-wet the fabric) and do not use wet steam.
Localized stains can be treated with a d-limonene (citrus) based cleaner (P21S Total Auto Wash) ensure surface is dry before use by leaving window cracked/open or SONAX NTS7 Upholstery Cleaner for BMW, Porsche and Mercedes-Benz Alcantara materials. Avoid alcohol, strong solvents or spirit based cleaners (particularly perchloroethyene and trichlorethylene).
Maintenance- in order to preserve your upholstery, vigorous cleaning of accumulated dirt should be avoided as dirt / grit is abrasive and may damage the finish.
It is therefore recommended that regular cleaning is carried out by brushing seating areas with a soft upholstery brush and then vacuuming to remove dust and loose dirt. Avoid rubbing too strongly. The use of steam machines is not recommended, although the use of dry-vapour steam is recommended
Weekly
Dust the fabric using a soft upholstery brush, and then vacuum. Then run a lightly damp micro fibre towel over the surface to remove any small dust particles.
Vir:
http://www.autodetailingnetworkforums.c ... It-4965831
Zadnjič spremenil Dräger, dne Ne Dec 18, 2011 7:12 pm, skupaj popravljeno 2 krat.
pa se strinjamo da je to umetna zadeva?
citiram:
Alcantara® je registrirana blagovna znamka nove generacije mikrofibre, tekstila, ki je ekskluzivno proizveden v ALCANTARA S.p.A
Zadnjič spremenil Gregson007, dne Ne Dec 18, 2011 7:11 pm, skupaj popravljeno 2 krat.
Dräger
Prispevkov: 2454
Zadnjič spremenil Dräger, dne Ne Dec 18, 2011 7:13 pm, skupaj popravljeno 1 krat.
Gregson
Prispevkov: 38
Pridružen: Pe Dec 16, 2011 8:11 am
Kraj: Rogoza
Komu znana http://www.avto.net/_AVTO/ad.asp?ID=5479039&show=1
bi bilo pri taki kilometrini (če je realna) potrebno kaj kongretnega menjat?
Miholl
Prispevkov: 5329
Vozilo: 156 sw
bobo69 napisal/-a:
Miholl napisal/-a:Ja kaj pa je po tvoje alcantara??
Malo si poglej po internetu, saj ni težko.
http://en.wikipedia.org/wiki/Alcantara_%28material%29
Kako pa jo potem čistiš, če ne veš kaj je?
Odslovim stranko... #-o #-o
Alcantari se ne reče zastonj "brušeno usnje", kemik pa res nisem tko da se opravičujem za zmoto ker ne poznam točne kemijske strukture.
kosir1234
Prispevkov: 3687
bobo69 napisal/-a:
Gregson napisal/-a:Si je kdo že šel pogledat ti dve 147:
http://www.avto.net/_AVTO/ad.asp?ID=5446635&show=1
ali
http://www.avto.net/_AVTO/ad.asp?ID=5459160&show=1
Pri drugi je glede na letnik in opombe verjetno že vsaj drugi glavni servis in alcantara vsekakor ni brušeno usnje - to ti lahko da odgovor o resnosti prodajalca.
Aja, po novem moremo meti vsi doktorat iz materialov, da lahko resno avte prodajamo? :lol:
Prispevkov: 6157
OFFFF:
Odgovor na kratko, že izpred časov, iz Alcantara s.p.a.:
Alcantara je čisto sintetični, umetni material, nanešen na mrežasto nosilno strukturo. Čisti se ga s suhim brušenjem in krtačenjem, ostanke se odsesa. Brusitit je treba, ko se pojavijo na površini prvi cofki. Bolj ko se večajo cofki pomeni, da je vse več materiala povleklo iz mreže. Tako lahko na koncu ostane samo prazna mreža in potem še luknja.
Smrt za Alcantaro je jeans.
Treba pa je ločiti med Alcantaro in Alkantaro. Alcantara je tista original, katero so začeli izdelovati v Italiji. Alkantara pa je novodobni Hitlerjev fejk, kateri po kvaliteti niti približno ne dosega prave Alcantare. Jo pa dobro tržijo, ker je ubijalsko draga kot dodatek v avtu.
Sama Alcantara pa je res podobna brušenemu usnju, katerega poznamo pod imenom semiš.
bobo69
Prispevkov: 103
Pridružen: So Jan 09, 2010 9:23 pm
Kot prvo nisem želel povzročiti vojne okrog alcantare in mislim da je dovolj OT.
Kot drugo, obstaja resnično brušeno usnje zato je prodajanje alcantare kot "brušeno usnje" zavajanje kupcev in prodajanje buč.
@košir1234, ni potrebno da imate prodajalci avtomobilov doktorat iz materialov, lahko pa bi vedeli kaj točno prodajate. Jaz osebno ne živim od preprodaje avtomobilov in si lahko privoščim napako in zamenjam kakšen pojem, preprodajalci s tem izgubljate verodostojnost. Pa brez zamere in LP :mrgreen:
jaka_speed
Prispevkov: 313
Pridružen: So Jan 16, 2010 9:46 pm
Gregson napisal/-a:Komu znana http://www.avto.net/_AVTO/ad.asp?ID=5479039&show=1
Pred nakupom odpelji avto obvezno na pooblaščeni servis,pa boš dobil odgovor.Lahko je cel kup stvari,lahko pa nič.
ZORE89
Prispevkov: 1374
Kraj: Zasavje
Pozna kdo tole 156 2.4 Mjet s TI opremo:
http://www.avto.net/_AVTO/ad.asp?ID=5479811&show=1
Ker se že kregate okoli alcantare... nobena alfa je nima, razen 159 TI letnik 2010 :D
To kar je v alfah je alfatex, ki je pač ena izvedenka velurja.
LaserJaMM
Prispevkov: 7497
TribesMan napisal/-a:Ker se že kregate okoli alcantare... nobena alfa je nima, razen 159 TI letnik 2010 :D
hehe si me prehitel :D
129ps
Prispevkov: 262
Pridružen: Sr Jan 11, 2006 5:19 pm
Vozilo: Alfe
Kraj: notranjska
ZORE89 napisal/-a:Pozna kdo tole 156 2.4 Mjet s TI opremo:
Že pokomentirano,poglej par strani nazaj :)
omahens
Prispevkov: 120
Pridružen: Pe Sep 23, 2005 1:42 pm
Kraj: Senovo
Morda pozna kdo tole 159 iz Velenja?
http://www.avto.net/2004/dealer_oglas.asp?ID=5219448
Piše, da je Progression, ampak po opremi sodeč je Disinctive....
Zaklenjeno
