Več o novem 150KM 2.0 JTDm motorju (2014+)
Toolox
Prispevkov: 978
Vozilo: Giulietta Super Veloce
Gtv 2.0 V6
Kraj: gorenjska
Tole me že nekaj časa grize: Na začetku sta bila za Giulietto dva 2.0 JTDM motorja. 140 in 170 KM.
V 2014 so začeli prodajat 150KM (110kW). Je ta motor natunan 140KM, zmehčan 170KM zaradi kakšnih okoljskih normativ, ali kompletno nov motor?
So potem sklopka in ostali deli navadni ali močnejši s 170 konjske Giuliette? Ta podatek pride prav pri čipiranju.
Prispevkov: 9758
Še vedno obstaja 175HP 2.0 JTDm... vendar samo v kombinaciji s TCT menjalnikom.
Brajda
Prispevkov: 33
Pridružen: Sr Jun 25, 2008 1:50 pm
Vozilo: 156, GT, MiTo, Giulietta
Kraj: maribor
zdravo! Sem novi lastnik 2.0jtd 150km (oktober 2013). Imam nekaj vprasanj. Pred kratkim mi je prodajalec avtomobilov opravil servis (olje, filter) saj je gorela opozorilna lučka (rumeni kljuc). po prevozenih 300km mi je avto zacel javljat menjavo olja, in utripa rdeca lucka za motorno olje. pozna kdo razlog? Katero motorno olje se najbolj priporoča? kdaj veliki servis? avto ima 143.000km. hvala
Tomas33
Prispevkov: 64
Ne vem, če ima senzor. Lahko, da je treba samo resetirat counter. Bodo drugi več povedali.
Tole je pa iz navodil.
ON CONSTANTLY: Low engine oil pressure (red)
FLASHING: Exhausted engine oil
(for versions/markets, where provided - red)
When the ignition key is turned to MAR, the warning light
switches on, but it should go out as soon as the engine is started.
1. Low engine oil pressure
The warning light turns on constantly along with a message on the
display (for versions/markets where provided) when the system
detects that engine oil pressure is low.
v
If the warning light vturns on when the car is
travelling (on some versions, together with the
message on the display), stop the car immediately
and contact Alfa Romeo Authorized Services.
2. Exhausted engine oil
(for versions/markets, where provided)
The warning light comes on flashing and a specific message will
appear on the display (for versions/markets where provided). The
warning light may flash in the following ways, depending on the
versions:
❍ for 1 minute every two hours;
❍ for three minute cycles with the warning light off for intervals
of five seconds until oil is changed.
After the initial warning, each time the engine is started up, the
warning light will continue to flash in the same ways as described
above, until the oil is changed. A specific message will appear on
the display (for versions/markets where provided) in addition to
the warning light.
Flashing of the warning light is not a fault but indicates that the
oil needs to be changed as a consequence of normal use.
Note that engine oil degrades faster under the following circumstances:
❍ mainly urban use of the car , requiring more frequent regeneration
of the DPF;
❍ use of the car for short drives, in which the engine does not
have time to reach its regular operating temperature
❍ repeated interruptions to the regeneration process signalled by
the DPF warning light coming on.
Exhausted engine oil should be replaced as soon
as possible after the warning light comes on, and
never more than 500 km after it first comes on.
Failure to comply with the instructions above may result
in severe damage to the engine and invalidate the warranty.
Remember that the operation of this warning light
is not related to the amount of oil in the engine. Therefore,
do not simply top up when the light starts flashing.
Edit: Izbrisan kopiran zgornji citat ....
didi
Prispevkov: 833
Če se je prizgala lucka za motor potem niso resetirali intervala!
Brajda
Prispevkov: 33
Kraj: maribor
Ja vrjetno so ga, glede na to da je najprej gorel rumeni kljuc, ki je javljal takojsen servis. Zdaj pa je izpis za menjavo olja. Ne vem.
Prispevkov: 9783
Kot je že "didi" omenil ...
Očitno je mehanik pri resetiranju pozabil obkljukat menjavo olja ...
SilverMan
Prispevkov: 1069
Vozilo: 147 JTDm 16v TbT
Kraj: Črnomelj
Če le ni pozabil tudi zamenjat olje in filter...
Prispevkov: 9783
Ta bi bila sploh dobra, ja ....
Brajda
Prispevkov: 33
Kraj: maribor
Ja sej, olje je že/še črno. Kak se da ugotovit, če so slucajno bli jermeni menjani?
didi
Prispevkov: 833
Ce se od zgoraj ne vidi nic, edino da razdres s strani pa pogledas (plastiko dol, kolo dol)... Ce pa nimas nobenga racuna o menjavi al pa cesarkoli pa verjetno ni blo menjan nic!
Edit: didi, komentarja, direktno nad tvojim odgovorom ti ni potrebno citirati ... :wink:
Brajda
Prispevkov: 33
Kraj: maribor
Nimam nic, avto je bil od operativnega lizinga in servisiran izkljucno v njihovih delavnicah. Je kaki recept da se preveri jermen?
didi
Prispevkov: 833
Kolk mas km? Mislm da je menjava jermenov predpisana pri Giuliettah tam okoli 140.000 ali 5 let. Kar pac pride prej. Druge opcije preverbe ni nobene razen da sam pogledas kot sem ti napisal! Valda mas kake racune, listke od servisiranja avta?!
Zadnjič spremenil didi, dne Sr Feb 14, 2018 2:44 pm, skupaj popravljeno 1 krat.
bacco979
Prispevkov: 78
Pridružen: Po Jun 03, 2013 7:34 am
Vozilo: 2014 Giulietta 2.0 16v
Jaz sem svojo kupil s 145.000 km, letnik 2014. Zadnji italijanski servis je bil pri 120.000 lani pozimi in niso menjali jermenov. Podatki o zadnjem servisu pa so na nalepki. Po servisni knjigi je servisni interval 35.000 km ali 2 leti, veliki servis pa pri 140.000 oz. na 5 let. Meni je jermene, šponarje in vodno črpalko zamenjal prodajalec.
stuhec
Prispevkov: 3153
če je 2015 letnik in 190 k prevozenih in ni nobnih papirjev, kako hitro vidis ce bilo kaj zamenjano?
super
