1.9 JTDIn kak motor bi ti notri dajal?
Torej, nihče ne ve, o čem se gre tukaj?
a turbocharger and a revolutionary scavenging control system that gets rid of any “turbolag”.
vir: http://www.atzonline.com/index.php;do=s ... =1/id=9770The performances of this engine are a result of the application of the Scavenging technology, which maximises the drive torque at low revolutions per minute by guaranteeing a very good engine response speed to any driver request. Scavenging can be obtained by controlling and optimising at every instant engine parameters such as dosage, position of the two phase transformers, ignition advance and injection timing. Basically, it is possible to define the angle and overlapping time of the valves with extreme precision in order to generate direct airflow from the intake to the exhaust manifolds and start the turbocharger in very short times. This means the engine can make better use of the supercharging when compared to standard turbocharged petrol engines. The system is managed by an innovative engine management control unit integrating a software which manages all parameters. Thus the maximum drive torque at 1400 revolutions per minute increases by 70 percent compared to traditional turbo engines and response times are halved, getting close to those of aspirated engines. The Scavenging strategy combined with the control system allows this engine to reach a high specific drive torque of 185 Newton metres per litre which can be reached at a relatively low speed of 5000 rpm and remains constant up to 5500 rpm.
Vprašanje - po mojem dosedanjem razumevanju pomeni supercharger kompresor, turbocharger pa turbinozdravc napisal/-a:tole sem nasel:vir: http://www.atzonline.com/index.php;do=s ... =1/id=9770The performances of this engine are a result of the application of the Scavenging technology, which maximises the drive torque at low revolutions per minute by guaranteeing a very good engine response speed to any driver request. Scavenging can be obtained by controlling and optimising at every instant engine parameters such as dosage, position of the two phase transformers, ignition advance and injection timing. Basically, it is possible to define the angle and overlapping time of the valves with extreme precision in order to generate direct airflow from the intake to the exhaust manifolds and start the turbocharger in very short times. This means the engine can make better use of the supercharging when compared to standard turbocharged petrol engines. The system is managed by an innovative engine management control unit integrating a software which manages all parameters. Thus the maximum drive torque at 1400 revolutions per minute increases by 70 percent compared to traditional turbo engines and response times are halved, getting close to those of aspirated engines. The Scavenging strategy combined with the control system allows this engine to reach a high specific drive torque of 185 Newton metres per litre which can be reached at a relatively low speed of 5000 rpm and remains constant up to 5500 rpm.
skratka s kontrolo nad kolicino vbrizganega goriva pri dolocenih obratih, spreminjanje timinga zapiranja in odpiranja ventilov, ipd.
Tako je.Vprašanje - po mojem dosedanjem razumevanju pomeni supercharger kompresor, turbocharger pa turbino
Točno tako. In ravno zaradi tega me je zdaj že v naprej strah. Kajti MiTo s prodajami dosti obeta, potem napovejo GTA vaerzijo, naredijo koncept, izdajo približne specifikacije, (ljude so vse mokri ko berejo in gledajo avto) potem pa projekt zamrznejo.rockson napisal/-a:Najprej je treba videti kako se bo model prijel na trgu - firma konec koncev potrebuje prodajne številke. Mokre sanje so v drugem planu. Če se bo model lepo prijel, bodo sigurno tudi kaj v tej smeri delali.
biturbo je lapsus s predstavitve, supercharging je pa glagol ki pomeni prisilno polnjenje in velja tako za kompresor kot turbino.alfa_samec napisal/-a:Tako je.Vprašanje - po mojem dosedanjem razumevanju pomeni supercharger kompresor, turbocharger pa turbino
Drugače pa, tudi meni ni več nič točno jasno, kaj želi kdo kaj s čim povedat. Najprej biturbo, pol el. sistem, zdaj kompresor vs turbo itd. itd.
Nedolgo nazaj je nekdo psoval, kako imajo nemci uradne trgovine za kupit njihovo škart robo in podobno...No, od včeraj jo ima tudi Alfa! (popravljam, NIMA, ker je že vse razprodano! Od včeraj!)
http://store.alfaromeo.com/
Nekaj sladkorčkov:
- jakna 273€
- polo majca 132 €
- usnjena jakna 540€
- kravata 42€ itd
Lepe cene, ni kaj
Tudi turbocharging je glagol. Imata sicer isti base form, samo ne pomenita isto, ker je prefix različen. Razlika je v načinu prisilnega polnjenja, ki je opisana zgoraj.supercharging je pa glagol ki pomeni prisilno polnjenje in velja tako za kompresor kot turbino.
Pogovorno že mogoče, ampak na žalost je kot večina izrazov s katerimi pavšalno opletajo s ključi vihtečimi posamezniki povsem napačno uporabljen.Alan napisal/-a:supercharging se uporablja pogovorno lahko za turbo in kompresor.
Matr zapenjate za vsako malenkost.
Turbina ima tudi kompresorski del če se že gremo u detajle.
Lahko je bit wikipedija pa google pameten
