Vici
Giorgio Armani
Prispevkov: 1184
> > Jack, a smart businessman, talks to his son.
> > Jack: "I want you to marry a girl of my choice"
> > Son: "I will choose my own bride!"
> > Jack: "But the girl is Bill Gates's daughter."
> > Son: "Well, in that case..."
> > Next Jack approaches Bill Gates.
> > Jack: "I have a husband for your daughter."
> > Bill Gates: "But my daughter is too young to marry!"
> > Jack: "But this young man is a vice-president of the World Bank."
> > Bill Gates: "Ah, in that case..."
> > Finally Jack goes to see the president of the World Bank.
> > Jack: "I have a young man to be recommended as a vice-president."
> > President: "But I already have more vice- presidents than I need!"
> > Jack: "But this young man is Bill Gates's son-in-law."
> > President: "Ah, in that case..."
Lp G.A.
AR-146
Prispevkov: 2668
Kraj: ljubljana
lolll huda
Giorgio Armani
Prispevkov: 1184
Tale je pa res huda :lol: :lol:
Koliko mora popiti povprečen dolenc, da napiha 0,5?
-14 dni nič!
Lp G.A.
zombi
Prispevkov: 1933
Pridružen: Ne Okt 12, 2003 7:58 pm
Vozilo: Alfa Romeo 159 2.0 JTDm
Grejo bjonda, crnolaska in rjavolaska v trgovino po vibratorje. Crnolaska
zbira, zbira pa kupi rumenga, rjavolaska zbira, zbira pa kupi zelenega,
bjonda zbira, zbira pa kupi rdecega.
Zvecer prodajalka poroca svoji sefici: danes sem prodala 2 vibratorja pa
en gasilni aparat.
stuntz
Prispevkov: 2340
Kraj: Zagorje
Se sprehajata in pogovarjata dva.
Prvi pripoveduje: "Pomisli, kakšna nesreča se mi je zgodila: Grem lepo po pločniku, se ozrem za lepim dekletom, naredim pri tem korak vstran, stopim na kolesarsko stezo, in me zadene kolesar, ki je vozil v napačno smer!"
Drugi ugovarja: "Temu jaz ne bi rekel nesreča, prej neprevidnost."
Prvi postaja ogorčen: "Ja seveda, za tebe je nesreča samo, če ti pade lonec z rožo na glavo!"
Drugi: "Zame je tudi to neprevidnost."
Prvi: "Kaj pa je potemtakem zate nesreča?"
Drugi: "Ja, vidiš, meni se je zgodila nesreča: Sprehajamo se po pomolu moja žena, moja tašča in jaz in gledamo morje. Tašča je stopila malo preveč na rob in je zdrsnila v vodo in se začela lepo utapljati."
Prvi mu skoči v besedo: "To je vendar neprevidnost, kako moreš temu reči nesreča!"
Drugi: "Točno, nesreča je prišla kasneje: en stupido marinaio se je potem pognal v morje in jo potegnil na suho! To je, vidiš, nesreča!"
stuntz
Prispevkov: 2340
Kraj: Zagorje
Žena se vrne iz službenega potovanja in doma vpraša moža: "Kako je kaj naša mačka ?"
Mož ji odgovori: "Ja, mačka je pa crknila."
Žena se razburi in napade moža: "Pa ti veš, da mi takšne slabe novice ne smeš povedati na tako grob način. Ti bi mi moral reči, da je mačka hodila po strehi, padla dol, si polomila tačke in da si jo zato peljal k veterinarju, ki je po svojih najboljših močeh poskrbel zanjo, vendar uboga muca ni preživela, zato smo jo lepo pokopali."
Mož si seveda misli svoje. Pa nato žena vpraša: "Kako pa kaj moja mama (tašča) ?"
Mož nekaj časa razmišlja, nato pa reče: "Ja, tašča je pa hodila po strehi......"
Fresh
Prispevkov: 708
Pridružen: To Dec 02, 2003 4:36 pm
LOL!
Fresh :lol:
Giorgio Armani
Prispevkov: 1184
Blondinka je imela financne tezave, zato se je odlocila, da bo
ugrabila nekega otroka in tako zasluzila z odkupnino.
Naslednji dan je odsla v park in zgrabila majhnega fanta, ga
odvlekla v bliznje grmovje in na list papirja napisala:
"Vas otrok je ugrabljen. Pustite jutri zjutraj ob 7:00 poleg
spomenika v parku 25.000 $ v rjavi torbi!" Na koncu se je
podpisala kot "BLONDINKA".
Nato je dala ta list papirja temu fantku in mu narocila, naj
gre s tem listom naravnost domov!!!
Naslednje jutro pride do spomenika in tam je res bila torba z
denarjem, kakor je zahtevala na listu. Poleg torbe pa
je bilo prilozeno pismo: TUKAJ JE VAS DENAR!!! NE MOREM
VERJETI, DA LAHKO ENA BLONDINKA KAJ TAKEGA
STORI DRUGI! Podpis: "BJONDA"
Lp G.A.
Fresh
Prispevkov: 708
Janez in sošolci iz faksa se pogovarjajo.
Sošolec1: Jes menjam olje v avtu na 6 mesecev, ker ga tko pulim...
Sošolec2: Mah jest ga menjam na eno leto, pa je več kot dovolj....
Sošolec3: Mah men je čist dost da olje zamenjam na dve leti, k se ne vozim tolk...
Janez: Mah jaz ga zamenjam na tri leta....
Sošolci vsi začudeni: Pa Janez, saj ti nimaš avta ....
Janez: Aja šit, sem pozabu o čem je debata. Jaz delam v McDonaldsu.....
Fresh #-o
Giorgio Armani
Prispevkov: 1184
Kako se stopnjuje pridevnik 'škrt'?
Medvode - Škofja Loka - Kranj - Radovljica - Jesenice! fantje brez zamere seveda :D :D
Mislim da tale še ni bila tukaj;
FW: kako veš, da nisi več študent
>1. Ob 6h zjutraj vstajas in takrat ne hodis spat,
>2. Seks v enojni postelji ti povzroca tehnicne tezave,
>3. V hladilniku imas vec hrane kot pijace,
>4. Tvojo fantazijo o seksu s tremi dekleti z lezbicnimi nagnenji je
>zamenjala fantazija o seksu s komerkoli,
>5. Ne strinjas se s testiranjem novih zdravil na prostovoljcih,
>6. Poznas vse, ki spijo v tvojem stanovanju,
>7. Ne prejemas grozilnih pisem iz banke,
>8. Svojo najljubso melodijo slisis v dvigalu firme, kjer delas,
>9. S sabo nosis deznik
>10. Sedemdnevne pijanice< se ti ne dogajajo,
>11. V trgovino ne hodis z vsemi prijatelji,
>12. Uporabljas vse obicajne placilne in kreditne moznosti svojega tekocega
>racuna,
>13. V stanovanju dela ogrevanje,
>14. Tvoji prijatelji se porocajo in locujejo, namesto da bi se srecevali in
>razhajali,
>15. Drzavi letno placujes 60.000 sit,
>16. Namesto 130 dni pocitnic, jih imas le 20,
>17. Kavbojke in pulover niso elegantna obleka,
>18. Klices policijo, ker prekleti mulci v sosednjem stanovanju nocejo
>stisati glasbe,
>19. Zgodaj vstajas s postelje tudi ce pada dež,
>20. Umivanje ni nujno obred.
>21. Starejsih sorodnikov ni sram pred tabo govoriti sal s seksualno vsebino,
>22. Pojma nimas kdaj zapirajo najblizji kiosk z bureki.
>23. Avtomobilsko zavarovanje je vedno cenejse, stroski vzdrzevanja pa vedno
>drazji,
>24. Idej za koktejle ne dobivas od lokalnih klosarjev,
>25. Nepojedene pice ne dajes v hladilnik za pozneje,
>26. Ne porabis polovice dneva za nacrtovanje vecernega pohoda po barih,
>27. Ne preneses prekletih studentov - parazitov,
>28. Ko si pijan ne cutis cudovite privlacnosti do prometnih znakov,
>29. Spanje v cakalnici zelezniske postaje se ti ne zdi spodobno,
>30. Sostanovalcev ti ne uspeva prepricati v pitje do jutra,
>31. Ko se zbudis, vedno ves kje si,
>32. Dremezi od 12 do 18 se ti ne dogajajo,
>33. Ogenj v kuhinji ni povod za dobro zabavo,
>34. V lekarne hodis po Panadol in ne po kondome in teste nosecnosti,
>35. Spominjas se imena osebe, s katero se zbudis,
>36. Zajtrke jes v casu zajtrka,
>37. V tvoji kuhinji ni ne misi ne scurkov,
>38. Nakupovalni seznam je daljsi od juhe iz loncka in kiste piva,
>39. Uporabljas sesalec,
>40. Krsenje zakona pomeni prekoracitev omejitve hitrosti za 10km/h,
>41. Vec kot 90% svojega casa ponavadi prebijes za racunalnikom,
>42. Namesto da bi rekel: "nikoli vec ne bom toliko popil, govoris: "ne morem
>vec spiti toliko kot vcasih"
>43. Ne eksperimetiras vec s prepovedanimi substancami,
>44. Ne pijes vec doma preden gres v bar, da bi tam prihranil.
Lp G.A.
zombi
Prispevkov: 1933
Tata: "Sine koliko je 1 + 1?"
Sine: "6!"
Tata: "Nije sine, vidi... imas jedno lizalo i ja ti kupim jos jedno, koliko ces imati?"
Sine: "4!"
Tata: "Ma nije sine (iznervirano) vidi,... imas jednu jabuku i dobijes drugu koliko ces imat?"
Sine: "Kilu..."
Tata: "E jebiga sine! Kucnem jednom, kucnem dva puta..."
Sine: "Tata, tata, neko kuca."
Tata: "Ma nije sine, ja sam..."
Sine: "Udji tata..."
Fresh
Prispevkov: 708
PREDNIKI
Mihec vpraša očeta:
- Očka, ali so bili res naši pred-
niki opice?
Oče ves razburjen odvrne:
- Tvoji že mogoče, moji pa prav
gotovo ne.
JEZIKAVOST
Uroš je razbil okno v učilnici in
učiteljica se je razjezila:
- Uroš, ali veš, kaj si si sedaj
prislužil?
- Me prav nič ne zanima. Če še ne
veste, hodim v šolo, da bi se
kaj naučil, ne pa da bi služil.
Fresh :mrgreen:
Giorgio Armani
Prispevkov: 1184
Po treh mesecih ljubezenske zveze je ona rekla:
"Sedaj bi bil pa ze čas, da me predstavis svoji druzini." "Nemogoče. Zena je v sluzbi, otroci pa v soli ..."
Lp G.A.
zombi
Prispevkov: 1933
Jedan putnik u avionu krenuo u toalet. Kako je muski bio zauzet (a njemu se zurilo) stjuardesa ga uputi u zenski WC, ali ga upozori da niposto ne dira dugmice sa natpisima: MTV, TTV, PMP i AVT. Nemogavsi da savlada svoju radoznalost, on pritisnu dugme MTV - i Mlaz Tople Vode mu zapljusne zadnjicu. Ugodno iznenadjen on pritisnu i dugme TTV, a
Talas Toplog zduha ga osusi. Nakon toga on pritisne i dugme > PMP - i
Pufna Mirisljavog Pudera ga fino zaprasi. Razmisljajuci o tome kako su
ove zene bas razmazene on pritisnu i dugme AVT i..... Nas putnik se budi u bolnici i unezvereno gleda oko sebe. "Gde je avion? Gde sam to ja?" - zbunjeno pita sestru koja se tu nasla. -Gospodine, Vi ste u bolnici. U avionu ste pritisli dugme AVT - Automatsko Vadjenje Tampona - Vas penis je ispod jastuka!
majaCRX
Prispevkov: 508
Pridružen: Sr Nov 26, 2003 7:02 pm
Kraj: SG
Trije mrtvo pijani Dolenjci gredo iz gostilne, po želežniških tirih.
Po nekaj korakih reče prvi:
Ne zastopm zakuga so dons štenge taku narazn...
Čez čas potoži drugi:
Kaku je ta agraja taku nisku pastaulena...
Pa se oglasi še tretji:
Konc prablema! Lift že prhaja!!
