točno to se dogaja moji 156-ki
kopirano iz
http://www.alfa156.net/
Sometimes on cold starts the engine has difficulty revving, but after a few
seconds of pumping on the accelerators the revs come back. The car will
still have a bit of a problem pulling away but a few secs later it will be
ok. After a couple of minutes things seem fine. No problems at all. This
mostly happens on hot days and if the car has been parked in the sun.
Then try turn off the engine when the problem occurs and start it up again.
If that helps, then this might be a problem with one of the following three things:
- Faulty O2 sensor (lambda sensor)
- Faulty water temperature sensor
- Faulty air mass meter (MAF) <- most likely & most expensive
This one can also be caused by the cables to the MAF gnawing against the
engine cover so bad that one or more of the cables snapped inside. Impossible
to see. Solved by cutting off 1 cm of the cable and attaching it again.
_________
Lmm ali maf je nov.Torej po vsej verjetnosti je lambda
Kolk $ je kej nova?
Pa tudi odklopil sem jo prej in se je dogajalo isto...
