Černobil in Pripyat
Uroš
Prispevkov: 3653
Kraj: Maribor-Tezno
Uroš
Prispevkov: 7131
Kaj hočmo - mesto duhov.
Drugač sem si ga pa malce v Stalkerju ogledal, pa še malce pregooglal na to temo.
DaviiD
Prispevkov: 1165
Pridružen: Če Jul 01, 2004 11:48 am
Kraj: Maribor
Ta je sla tudi veckrat tja - zanimive slike:
http://www.angelfire.com/extreme4/kiddofspeed/
innesi
Prispevkov: 821
Pridružen: Sr Sep 01, 2004 8:07 pm
Kraj: Maribor
Uroš: tale link ki si ga prilepel ima res dobre slike...
ker ne razumem niti znaka kaj piše mi lahko kdo pove če je kje možn tisto stran spraviti v angleški pogled :oops: :oops:
pa drgac a tistle bloki ki so na eni od slik (ogromno blokov) to je vse prazno?
Upornik brez razloga :)
kocko
Prispevkov: 442
Pridružen: Sr Sep 01, 2004 3:25 pm
innesi napisal/-a:ker ne razumem niti znaka kaj piše mi lahko kdo pove če je kje možn tisto stran spraviti v angleški pogled :oops: :oops:
The second trip to the exclusion area of Chernobyl' AES proved to be considerably more interesting than the last year's, was said as that was to 6 hour more than time, so also that that we have the outstanding tracking in face of Aleksandr (planca, the administrator of project pripyat.com) and Yuri from Chernobyl'interinforma. Apropos of the risk (many they ask), I want to say the following: external gamma-background in the zone by itself large danger does not present (with exception of several places, where accompanying nevertheless you not tyuey povedut and they will not release), at the height of 10 km the power of the exposure dose of gamma-radiation is from 200 to 600 R/h, so that the dose obtained by us in the day is completely compared with one transatlantic flight. Danger presents risk to inhale hot particle, piece of nuclear fuel from the reactor. Probability this scanty, with the observance of safety and of rules technique of behavior in the zone approaches zero, but it exists; therefore each solves for itself, well and 4 already long ago for itself all solved J they left from Kiev in 7:30 mornings on the microbus with the conditioner (hurray!), in Dityatkakh were already about 9 hour, then they stopped in that completely becoming the impervious jungle it sat down To zales'e, in which there were once more than 2 thousand inhabitants, then they dropped in into Chernobyl' to the short briefing, well and after this to the side of previously obeshchannogo of Sasha surprise. By surprise proved to be interesting place - the third turn (unfinished 5th and 6th blocks CHAES) and cooling tower - the enormous, monumental construction, which were being intended for cooling the water. The nearer we approached the cooling towers, the more persistent the arquebus our radiometers, these places did not pass deactivation and visitors they did not there earlier conduct generally, we proved to be by the first guests there J sufficient was to present more closely to the moss inside the cooling tower radiometer, as the number of beta disintegrations on the indicator in schitannye seconds it went off scale for one-and-a-half thousand, but gamma-background was there more than 500 R/h. Then they went to the inspection near the object "shelter". Wind blew from the station to us; however, background on area was about 400 R/h, which is 3 times less than during June of past year, it seems that the work on strengthening and repairing the sarcophagus occurs sufficiently effectively. Pripet... city- spectre, the city, which greater is not on the maps, the city, about which nothing know many people, city, which through several years will become ruins, but about which they will always remember those, for whom this is important, city... Much we walk, on the street of heat, more than 30 - each pair it is hour - into the bus, to be cooled and to cut through. The many thanks to Sasha - was conducted us by very interesting route and much they had time to look: DK power engineer, sportkompleks, one of the stores, the park of attractions, the hospital (truth they spoke, actually very gloomy place with the strange sensations inside), into which they brought the first injured from acute radiation sickness firemen, dining room, school, fire part, prison (building GUVD), pond. In the prison in one of the cameras old archive cards with surnames and addresses of those delayed found, children promised to otskanirovat' and to lay out them to the forum. They found the strongly fonyashchiy excavator ladle- seizure. It was amusingly control the fact, as Sasha and Jura Mountains with the hysterically squeaking radiometers with the enthusiasm they find flash point on it, and people will slowly move away from there further than J they measured they there azh 16 mr/h, this very considerable. They saw the acting laundry in the Pripet, in it is processed special clothing of workers CHAES. We go to fujiyama (roof of y'-tietazhki), along the way into several apartments, into Chernobyl' - to reap, and we return to Kiev. They thus far passed the place, where there was once red forest, the indications of radiometers barely did not have time to reach the mark 2000 R/h...
Prevod by "babelfish" :D (http://babelfish.altavista.com/)
Uroš
Prispevkov: 3653
Kraj: Maribor-Tezno
Celo mesto Pripyat je popolnoma zapuščeno !
Uroš
innesi
Prispevkov: 821
Kraj: Maribor
kocko: hvala za prevod :)
Uroš: hvala za pojasnilo...mal sem premlada da bi vedela kaj se je dejansko dogajalo tistega usodnega leta 86 :oops:
H.P. BaXXter
Prispevkov: 1498
Pridružen: Ne Feb 12, 2006 7:57 pm
Kraj: Lj
pa se je varno tam sprehajat?
FuManchu napisal/-a:V moji dvoletni alfistični karieri sem ugotovil, da je najpomembneje biti član AMZS (zastonj šlep :lol:)
prjatu
Prispevkov: 3940
Če se ne zadržuješ predolgo ni nobene panike, res pa je, da stopnja radiacije po celotnem območju precej niha
pa še mal slikc
klik
klik
Uroš
Prispevkov: 3653
Kraj: Maribor-Tezno
Pripyat je najmlajše mesto nekdanje SZ, saj je bilo zgrajeno za inženirje in ostale zaposlene v Černobilu v začetku 70 let. Bilo je polno parkov in baje precej lepo takrat, nekaj slik : http://pripyat.com/ru/photo_gallery/before_1986/
Uroš
Teo
Prispevkov: 9750
Kraj: Slovenska Bistrica
Sapo jemajoče slike. Res odličen link.
Uroš
Prispevkov: 3653
Kraj: Maribor-Tezno
Še malo slik :
http://pripyat.com/ru/photo_gallery/pripyat/
MIMOGREDE, POD TO SLIKO PIŠE DA GRE ZA KAVČ JUGOSLOVANSKE IZDELAVE
Uroš
innesi
Prispevkov: 821
Kraj: Maribor
pa se sploh lahko gre tja tko prostovoljno ali je prepovedano?
http://en.wikipedia.org/wiki/Chernobyl_disaster
pa še slo: http://sl.wikipedia.org/wiki/%C4%8Cerno ... sre%C4%8Da
Uroš
Prispevkov: 3653
Kraj: Maribor-Tezno
Se organizirajo enodnevni izleti!
For those wishing to participate in a trip to Pripyat and the Chernobyl Exclusion Zone planned for October 20, 2007:
Pripyat. This word causes the unique associations in each of us. At once we shall exclude for whom they are reduced only to the place name of the river proceeding on territory of Ukraine. We shall recollect people, for which Pripyat – the house or a battlefield with the invisible enemy – radiation. Their associations are full of bitterness, disappointments and pains. There are still we, whose life has been never directly connected with City and the Zone. But aspiration not only to know history, and and to manage to experience it pushes on an original feat – to overcome in a different degree illness storming in us a radiophobia and to touch to tragedy not only separately taken city or the country, but also all mankind.
It is impossible to remain indifferent to picturesque landscapes of the Ukrainian Polesye and enigmatic silence of the thrown villages. It is impossible not to be terrified for a huge monument of human carelessness – to "Sarcophagus". It is necessary to hear breath of Pripyat. Cities which already more than twenty years live in loneliness. Which understands us and accepts such what we are. Us going to them from all world behind beautiful kinds from a roof шестнадцатиэтажки and grafitti on its buildings, us, admirers of game «Stalker» and simply were interested and sympathizing. The city waits for us – welcoming smiling, squinting weak-sighted eye-sockets of windows, absorbs sides of houses our shadows, gropes hands of prospectuses our traces. Glance to it in soul. Experience history. Understand, that for you the word "Pripyat" means.
The maximal structure of group - 40 people.
Departure Kiev, by comfortable bus MAN (DVD, a climate-system)
Route/Itinerary:
7.00-7.30 Meeting at the bus at the terminal "Southern" central station in Kiev
9.30-9.45 Check of documents at the check point Dytyatky "ДИТЯТКИ"
10.30-10.50 Arrival in Chernobyl town. Conversation with representatives of the Ministry of Emergency Measures of Ukraine
11.00-12.00 Tour Chernobyl town (museum of the technics which is taken part in ЛПА; a cemetery of the ships; church)
12.30-12.45. Visiting of viewing platform ЧАЭС (Chernobyl Plant)
13.00-17.00 Pedestrian walk by groups of 10-12 people in Pripyat, the story about life in the city before the accident on ЧАЭС and evacuations. The groups will be accompanied by former residents of Pripyat and editors of the site PRIPYAT.com
18.00-18.30 Supper in Chernobyl town (At will, cost 11 c.u.)
21.00-21.30 Arrival in Kiev, on. Terminal " Southern " central ж.д. Station
Cost of participation in a trip - 60 c.u.
На заметку Possible forms of payment for participation in a trip (payment of organizational and transport charges):
1. Credit Card (ГРН, РУБ, USD, EURO)
To pay by credit card, it is necessary to specify the method of payment in your application as: Credit Card. Payment is required within 3 working days from the moment you submit your application.
2. Webmoney
To pay by Webmoney, it is necessary to specify the method of payment in your application as: Webmoney and specify your WMID (the personal identifier in the Webmoney system) is necessary to specify a way of payment in the application form for participation: Webmoney and to specify the WMID (the personal identifier in payment system Webmoney). Payment is required within 3 working days from the moment you submit your application.
3. Cash (only for those in Kyiv)
For payment by cash, it is necessary to specify the method of payment in your application as: Cash. Payment is required within 3 working days from the moment you submit your application
Uroš
Uroš
Prispevkov: 3653
Kraj: Maribor-Tezno
Še malo da vas "zapalim"
Vojaške antene visoke 150m! :
http://pix.fine.kiev.ua/egor/gallery/0000b02w
http://wikimapia.org/455/
Uroš
