Stran 1 od 2
Alfa 156 - Nasveti pri nakupu
Objavljeno: Ne Apr 17, 2005 4:10 pm
Napisal/-a Cuore Sportivo
.: Alfa Romeo 156: nasveti pri nakupu :.
* Check that Air Con is working
* Look for corrosion over windscreen and on roof
* Listen for clunks from front ball joints
* Cam variator rattles from Twin Sparks (
read more here )
* Check for flaky paint on front bumper (
read more here )
* Make sure rear brakes haven't seized/corroded
* Check if all interior/dashboard lighting is still working
* Check engine under tray isn't smashed - it'll ground out otherwise.
* Check suspension for creaks over bumps (
read more here )
* Check alarm arms properly
* Check for oil leaks (it stungs a fortune for leaky balancer shaft seals)
* Run air con on coldest setting whilst you test drive it then feel round
the spongy gasket on the plastic housing in the middle of the bulkhead to see if it gets wet.
* Test drive it in the wet and go through every puddle you can find - then check
the carpets for water. (
read more here )
* If you're buying from a dealer dont take the warranty if its a WHA warranty (they're 5hite)
* Check edge of drivers seat for wear on the piping.
* Check when the cam belt was last changed! (
read more here )
http://www.alfa156.net/buyersg.html
http://www.cuore-sportivo.co.uk/diagnosticpage.html
http://www.alfa156.net/fr_index.html?/info.html
http://forum.alfa156.net/
sticky??
Objavljeno: Ne Apr 17, 2005 4:47 pm
Napisal/-a BossM
Uporabno!
Objavljeno: Ne Apr 17, 2005 5:14 pm
Napisal/-a mikkaa145
Objavljeno: Ne Apr 17, 2005 10:48 pm
Napisal/-a LaserJaMM
Objavljeno: Pe Jun 03, 2005 10:55 am
1. sticky
2. prevest ne znam vsega
3.
Test: JTD (150cv) vs. V6 (192cv)
kupujem 156
Objavljeno: So Jul 15, 2006 1:21 pm
Napisal/-a strozL
Tako prisel je cas da tudi jaz nabavim nek avto. odločil sem se za alfo 156.
kupujem mašino 1.6 al pa 1.8TS, kiliometrov manj kot 120000 letnik 00 ali 01, dnarja dam pa okol 1500000sit.
zanimajo me vaši nasveti na kaj moram pazit pri nakupu, kakšne posebnosti, itd...
p.s. lep pozdrav vsem na forumu
Re: kupujem 156
Objavljeno: So Jul 15, 2006 1:38 pm
Napisal/-a Beny
strozL napisal/-a:Tako prisel je cas da tudi jaz nabavim nek avto. odločil sem se za alfo 156.
Uporabi malo ikono SEARCH , ker je o tem že zelo veliko napisanega...
Pa dobrodošel na forumu
Objavljeno: So Jul 15, 2006 7:14 pm
Napisal/-a tito156
Dobrodošel
Kupi vsaj 1.8,boš bolj zadovoljen
Objavljeno: So Jul 15, 2006 7:45 pm
Napisal/-a apersa
mam za prodat 156. 2.0 ts sport paket letnik 2000
cena pa mal čez 1500000,razlike med 1.8 ni sm ta da pijeta isto pa cestnina je za 6 jurjev dražja zavarovanje je isto
http://www.avto.net/2004/osebna/oglas.asp?id=922675#
evo poglej pa se odloči lahk pokličeš pa se pomeniva je pa vse porihtano servis itd
Objavljeno: So Jul 15, 2006 11:09 pm
Napisal/-a guma
apersa napisal/-a:mam za prodat 156. 2.0 ts sport paket letnik 2000
Jaz ti priporočam, da avto kupiš na tak način (najdeš nekoga, ki prodaja na forumu in je naredil vsaj kakšen servis itd.), ker lahko z iskanjem pri raznih xy dilerjih hitro obupaš. Jaz sem danes gledal Alfo 156 SW v Kopru pri Trgo pa še nekaj (ni Trgoavto, prodajajo Renaulte) za slabe 3 milijone in je bila v zelo slabem stanju. Pisalo je, da je odlična, ampak čisto pokrivljen voznikov sedež, zjebani amortizerji zadaj itd. Naj te lepota ne zavede, je fino, da je tudi kakšna stvar poštimana.
Objavljeno: Ne Jul 16, 2006 9:13 am
Napisal/-a Ronnow
Ne kupuj alfe, baje da žre olje
Objavljeno: Ne Jul 16, 2006 11:39 am
Napisal/-a Teo
Tole je odličen nakup. Ker so itak vsi alfini motorji od 1.6 do 2.0 skoraj enaki, v porabi praktično ni razlike, pelje pa se 2.0 mnogo, mnogo bolje.
Objavljeno: Ne Jul 16, 2006 3:31 pm
Re: Alfa 156 - Nasveti pri nakupu
Objavljeno: Ne Jul 16, 2006 4:56 pm
Napisal/-a crnogorac
Cuore Sportivo napisal/-a:.: Alfa Romeo 156: nasveti pri nakupu :.
read more here )
read more here )
read more here )
read more here )
read more here )
sticky??
pa cela filozofija je tu o nakupu ar-156 joj joj joj prevec zame
crnogorac-krško
Objavljeno: So Jul 22, 2006 9:31 am
Napisal/-a OFC
Eno vprašanje: kupil sem AR 156 1.9jtd pa me zanima kaj bi bilo lahko narobe, (če je sploh kaj narobe) ker se mi iz auspuha kar lepo pokadi ko pritisnem na gas? Zdej pa ne vem, a je to normalno, ker nikoli še nisem imel dizla, ali,... Avto imam v garanciji, drugače zelo lepo ohranjen, je pa tik pred glavnim servisom (140000 km). A bi lahko bilo kaj resnega ali so kakšni filtri ali podobno?
Hvala za odgovore
