Driveline
longitudinal engine at front with front wheel drive or four wheel drive
Suspension
front : MacPherson strut with telescopic dampers and coil springs plus anti-roll bar
rear : dead beam axle with telescopic dampers and coil springs, located by Watts linkages and a panhard rod
wheelbase : 2450mm (Estate versions : 2455mm)
front track : 1364mm to 1392mm (depending on model)
rear track : 1359mm to 1364mm (depending on model)
Brakes
front : discs (ventilated on some models)
rear : drums or discs
handbrake operating on the rear via cable
dual hydraulic circuit with servo assistance
Gearbox
4 and 5 speed manual
Steering
Rack and pinion
power assistance on some models
Bo bolši pospešek.
Sam drgač pa kr leti tale 33-ka.
ne ga srat, že tako je preglasna. Samo cat. ven vzemi pa je. Pospeške imaš napisane v knjigi z navodili na koncu. Če rabiš navodila za servisiranje, pa recimo vse o računalniku >(bosch motronic MP 3.1) it.. pa povej oz. pridi na naslednje srečanje, pa ti prinesem na CDju.
