4 kolesno krmiljenje ki ga sploh ne razumem. kako je možno da se zadnje kolesa nad 60km/h obračajo v isto smer kot sprednja - sploh zavije kaj
še en zanimiv poslentek - Renault Laguna GT vs Porsche Boxter S http://youtube.com/watch?v=QaTnd3ozcaE
where do you get this things from dude...
Porsche Boxter S is a s**** anyway
Pri visokih hitrostih pa tako kot si omenil:At low speeds, the clever system is designed to boost manoeuvrability, so below 37mph the rear wheels turn in the opposite direction to those at the front. They can only rotate by 3.5 degrees, although that’s still enough to cut the standard Laguna’s turning circle from 12.05 metres to 10.80 metres.
Above 37mph, the rear wheels are programmed to turn in the same direction as those at the front, to boost stability and road holding. At these speeds, the rear axle permits only two degrees of turn, while the maximum turn angle of 3.5 degrees is available only during emergency situations.
It’s at higher speeds that the set-up really impresses, though. There’s more feel than in the regular model, and the Active Drive chassis is extremely effective at controlling body roll.
ja....tudi mene ni nevem kako ušeč. sej sprdni del ni napačen, ampak rit je pa obupna. v tej različici (sport gt al kako je že) pa mi slpoh ne zgleda napačna. bol kot zunanjost pa me prepriča notranjost. sedi se zelo dobro, armaturna pa deluje precej inovativnoUroš napisal/-a:Saj res da ima vsako oko svojega malara, ampak nova Laguna je pa tako ekstremno grda da malar oslepi !
Pravi prvi avto za slovenceljna, drugi pa Golf.
Se strinjam da je grda ma fotr navadno 2.0 dci. Sprednje luči bodo kmalu do brisalcev gor potegniliGorkichev napisal/-a:ja....tudi mene ni nevem kako ušeč. sej sprdni del ni napačen, ampak rit je pa obupna. v tej različici (sport gt al kako je že) pa mi slpoh ne zgleda napačna. bol kot zunanjost pa me prepriča notranjost. sedi se zelo dobro, armaturna pa deluje precej inovativnoUroš napisal/-a:Saj res da ima vsako oko svojega malara, ampak nova Laguna je pa tako ekstremno grda da malar oslepi !
Meni pa Laguna nikakor ni grd avto, ok zadk bi lahko bil malce bol zakljucen, ampak nasplosno ni slab avto, ni pac povprečen in na prvi pogled prjazn. Seveda ni kakor Laguna coupe concept, ampak dalec od grdega avtomobila kot npr. Megane ali Vel satis. Ce bi kupovat avto tega razreda in da je nov, bi meni osebno bil kar problem med Laguno, Mazdo 6 in Alfo 159.Teo napisal/-a:To pa res, jaz ko sme jo prvič videl, sem mislil, da so se zmotili. Sedaj ko so naredili pri Mercedesu še GLKja vidim, da s etrend odurno grdih avtomobilov nadaljuje.
