Kje trenutno najceneje do dobrih zavor AR 156 1.9 jtd SW
Miholl
Prispevkov: 5329
Vozilo: 156 sw
Kraj: Novo mesto
Pa maš tut enake ploščice??
No še dobro da si dovolj vztrajen :D
Očitno Green stuff za prednjo os ne pašejo na 2.4 20V. Zgleda kot da ima 2.4 20V drugačne čeljusti... :/
Na tvoj avto pašejo druge ploščice...
Brake Pads EBC-Greenstuff Alfa 156 / GT
for the following Alfa Romeo at the front axle!
Alfa 156
Model:
2.4 JTD 20V 175 BHP as from 2003 ->
Alfa GT
Models:
2.0 JTS as from 2004 ->
1.9 JTD 150 BHP as from 2004 ->
"Normalne" EBC Green stuff za prednjo os pašejo na:
Brake Pads EBC-Greenstuff Alfa 145/146/147/156/166/GTV/Spider
for the following Alfa Romeo!
Alfa 145 / 146
Models:
1.8 TS between: 97 -> 2001
2.0 TS between: 95 -> 2001
Alfa 147
Models:
1.6 TS 88 KW for 2000 ->
2.0 TS for 2000 ->
1.9 JTD for 2000 ->
Alfa 155
Model:
2.0 Turbo between 95 -> 1997
Alfa 156
Models:
1.6 TS for 2001 ->
1.8 TS for 2001 ->
2.0 TS for 97 ->
2.5 V6 for 97 ->
1.9 JTD for 2001 ->
2.4 JTD between: 97 -> 2003
(not the 2.4 20V for 2003)
Alfa 166
Model:
2.0 TS as from 99 -> onwards>
Alfa GTV / Spider (with ATE-Brake system from VET-NR.6009486)
Models:
2.0 TS for 97 ->
2.0 Turbo for 95 ->
EBC Green stuff za zadnjo os:
Brake Pads EBC-Greenstuff Alfa 147 / 156 / GT
For all Alfa Romeo to rear axle:
Alfa 147
Models:
1.6 TS 77 & 88 KW between 2000 ->
2.0 TS between 2000 ->
3.2 GTA between 02 -> 2003
1.9 JTD between 2000 ->
Alfa 156
Models:
1.6 TS between 2002 ->
1.8 TS between 2002 ->
2.0 TS between 2002 ->
2.5 V6 between 2002 ->
1.9 JTD between 2002 ->
2.4 JTD between 97 -> 2003
2.4 20V between 2003 ->
Alfa GT
Models:
2.0 JTS between 2004 ->
1.9 JTD between 2004 ->
Miholl
Prispevkov: 5329
Vozilo: 156 sw
Kraj: Novo mesto
Se mi je zdel da neki ne bo štimal :)
punkfan
Prispevkov: 457
Kraj: prestolnica
Je kdo dajal greenstuff na OEM diske?
bass
Prispevkov: 3874
Nekaj časa bo špilalo, dokler jih konkretno ne zvije.
Alchi
Prispevkov: 943
Pridružen: Pe Jul 13, 2007 12:29 pm
Kraj: Novo mesto
Mi lahko kdo potrdi sledeče:
Moja AR 156 1.9 SW JTD ima serijsko spredaj zračno hlajene diske premera 284 mm?? Predvsem me zanima če res drži ta podatek: 284 mm?
bass
Prispevkov: 3874
Dve velikosti/debelini sta. Premeri, da boš siguren, je pa najverjetneje 284 ali 281 se mi zdi da je tadruga varianta.
Alchi
Prispevkov: 943
Kraj: Novo mesto
Huh, ni mi lušt zdej snemat dol felten....Ve kdo 100% kaka je "stock" dimenzija?
Creed
Prispevkov: 4301
284mm...usaj moja 147JTD in alrotova 156m-JET imata tako dimenzijo.
Če so zračno hlajeni so sigurno 284mm, če niso so sigurno 281mm
Alchi
Prispevkov: 943
Kraj: Novo mesto
zračni, torej definitivno 284mm....tnx
blazo
Prispevkov: 139
Pridružen: To Avg 26, 2008 10:16 am
Bom kar tukaj vprašal, sej mogoče ni najboljša tema sam vseeno.
Bral sem nekje, da je minimala širina diska na zadnjih zavorah za 156 9mm-ali se motim?
zanima me v kolikor je ta širina manjša, kako lahko to vpliva na varnost vožnje oz. kdaj je potrebno menjat zadnje diske in ce je to ze kritično..
mislim da imam zadaj okoli 8 mm.
marius
Prispevkov: 169
Pridružen: Ne Sep 09, 2007 1:15 pm
Vozilo: AR156 2,4JTD 2000
AR156SW 2,4JTD 2001
AR147 1,9JTD 2002
AR Spider 2,0T.S. 1998
Kraj: Prevalje
Potem bo potrebno počasi razmišljati o menjavi zadnjih diskov in ploščic.
Ja, novi so 10mm, minimalna debelina pa je 9mm...
Gricko
Prispevkov: 995
Vozilo: 156Sw
Koliko vas je sedaj kupilo te Turbo groove brake disc ??
Namreč moji prednji so diski za zamenjavo :doubt:
Torej kako dobro vstavljajo
Koliko so kaj glasni (koliko ropotajo??)
Namreč slišim da naj bi bili vsi te diski , ki so narezani dokaj glasni???
@miholl cena 135€ za par še velja???
