"cviček" ;)
Uroš
Prispevkov: 3653
Kraj: Maribor-Tezno
prva meni nejasna zadeva je zakaj imamo že ene tri enake teme ...
npr ta; viewtopic.php?t=19193&postdays=0&postorder=asc&start=0
viewtopic.php?t=1461&postdays=0&postorder=asc&start=0
druga pa, zakaj sploh gnjavite s tem, kdo želi si naj tanka cviček, cekin ali dizel...
Razlike pa definitivno so, vprašanje je le koliko škodijo našim motorjem.
Kurilno olje ekstra lahko (KO EL)je gorivo za ogrevanje v gospodinjstvih. Uporaba tega goriva za pogon motorjev ni dovoljena (je kazniva).
"Navadnega" kurilnega olja v sloveniji nimamo. Poleg ekstra lahkega obstajajo še težje frakcije kurilnih olj, ki pa že spadajo v skupino t.i. "mazutov", uporabnih ponekod v industriji in se od KO EL precej razlikujejo.
Podoben derivat, kot KO EL, je dieselsko gorivo.
Glavne razlike:
- Vsebnost žvepla: KO EL-maks.2000 mg/KG, DIESEL- maks.50 mg/kg;
- KO EL je dodatno obarvano in vsebuje markirni indikator;
- Predpisane nizkotemperaturne lastnosti diesla so v primerjavi z KO EL bistveno ostrejše
- Aditivi
še malo:
Mixture
Shortages in some types of fuels sometimes results in distributors blending fuels like kerosene, jet fuel and different diesel types with traditional heating fuel into one fuel. This fuel is then sold as home heating fuel. Furnaces that burn heating fuel are more forgiving than vehicle engines are, so this blending is not a problem. Diesel engines require higher-quality fuel so that the fuel burns consistently and generates the proper compression, so this blend would negatively impact the engine's performance.
Engine Wear
Preventing engine wear is a critical attribute of diesel fuel. Heating fuel lacks an additive which lubricates the piston and o-rings. Without this lubrication the engine will quickly seize up. Diesel fuel contains this additive. According to Exxon Oil Company, this additive has been required and included for several years.
Uroš
