Zadnjič se mi je zgodilo, da mi Alfica ni vžgala, je pa mi vžgala čez cca. 15 min, zato sem jo spet malo priklopil na FiatECUScan in našel dve napaki.
Bi me moralo kaj skrbeti?
Pri kodi P0335 piše da se je prižgala kontrolna lučka, ampak se mi ni, pa čeprav sem jo testiral in dela.
Hvala za odgovor!
Poročilo:
CONNECTED TO:
ALFA 166 2.0 V6 TB
Bosch Motronic ME 2.1 (2.0 V6 TB)
READING ERROR CODES:
1: P0335 - Senzor broja okretaja
The ECU does not receive correctly the engine revolutions signal.
ATTENTION: this signal can be emitted in case the engine has not been started or in case the starting attempt has not been tried (in case the engine does not start). In case, check:
1) connections and plugs
2) continuity of wires from the sensor to the ECU
3) cleaning and air gap of the sensor
4) sensor functioning by means of the oscilloscope
The reason for this fault is that ECU has received invalid signal from the sensor. The fault is not detected now, but it is stored in memory. Clear fault codes, and observe for future appearance of the same fault. Dashboard warning light was activated for this fault.
2: P0330 - Senzor detonacija 2
The ECU does not receive correctly the signal from the signalled knock sensor. Probably the harness is interrupted or a SC is present, or the sensor itself does not work correctly. Check the harness and connections condition and check the sensor functioning by means of an oscilloscope or a voltmeter in V/PEAK by beating on the sensor clamping screw.
NOTE: it is necessary to comply with the driving torque of the sensor since an improper torque may alter the sensor correct functioning
The reason for this fault is that ECU has received very high signal from the sensor. The fault is not detected now, but it is stored in memory. Clear fault codes, and observe for future appearance of the same fault. Dashboard warning light was not activated for this fault.
