Overall Length 3989 mm
Overall Width 1864 mm
Overall Width / door mirrors 2090 mm (1864 mm without mirrors)
Overall Height 1183 mm
Wheelbase 2380 mm
Chassis carbon fiber monocoque
Dry Weight (ISO 1176:1991 cod. Iso M01-4.1) 895 kg
Number of Cylinders and Displacement 4 cylinders, 1742 cc
Engine Mount Position Mid
Engine Orientation Transverse
Max power 241/6000 rpm
Max torque 350Nm/2100-3750 rpm
Front Brake Type / Discs Size Ventilated drilled discs / 305×28 mm (4 pot)
Rear Brake Type / Discs Size Ventilated drilled discs / 292×22 mm
Maximum deceleration during braking (g) 1.25
Braking distance 100–0 km/h (m) 36
Front Suspension Type Double wishbone
Rear Suspension Type McPherson
Acceleration 0-100 km/h 4,5 sec
Top speed 258 km/h
Maximum lateral acceleration (g) 1.1
Drive Type Rear Wheel Drive
Transmission Alfa TCT (Dual Dry Clutch) 6 speed + reverse
Steering mechanical rack and pinion (2,75 lock-to-lock)
Fuel Tank Capacity (liters) 40
Fuel Consumption (l/100km) on Combined Cycle 6,8
Fuel Consumption (l/100km) on Urban Cycle 9,8
Fuel Consumption (l/100km) on Extra-Urban Cycle 5,0
CO2 Emissions (g/km) 157
EU Emissions Standard E6
Efficiency class G
Boot Capacity (dm3) 110
Number of seats 2
A ni to samo ena narejena in samo eno bo vedno.sasoz napisal/-a:kaj se je pa s tole zgodl da ni nikol v proizvodnjo prišla?
http://www.youtube.com/watch?v=iwh02a9sC7w
