minimi napisal/-a:Izglega top
Zdaj pa pridno varčuj za gume
Sem šel bolj na bottom kot top izgled, ampak tnx useen
Z gumami ne pričakujem prevelikih problemov, so pa potrošni material in če držijo več kot dve ali tri sezone, potem nekaj ne štima
Razen... če si nekako vedel, da so te pri koncu in da moram spomladi kupit nove
bananaman napisal/-a:
MaStr napisal/-a:Black mamba!
The black mamba (Dendroaspis polylepis), also called the common black mamba or black-mouthed mamba, is a highly venomous snake of the genus Dendroaspis (Mambas), and is endemic to sub-Saharan Africa. It was first described in 1864 by Albert Günther. It is the longest species of venomous snake in Africa, and the second-longest venomous snake in the world after the King cobra. It is also the fastest moving snake in Africa, and
one of the fastest moving snakes on the planet, perhaps the fastest,[4][5][6] capable of moving at 11 km/h (6.8 mph) over a distance of 43 m (141 ft).
The venom of the black mamba is highly toxic. Based on the median lethal dose (LD50) values in mice, the black mamba LD50 is 0.28/0.32 mg/kg subcutaneous.[7][8][9] Although there are other venomous snakes that exhibit higher LD50 toxicity scores, its venom is one of the most rapid-acting. In cases of severe envenomation, it is capable of killing an adult human in as little as 20 minutes.
vir: wikipedia
comment: I approve
