To pa nisem pogledal (nimam OBD2 naprave). Moram pa sedaj januarja mali servis narediti pa sem takrat mislil povedat mehaniku naj preveri napako. Pomoje da je ista P1177 in P1178 mixture strenght 1 & 2.alfa_samec napisal/-a:Javi isto napako ali katero drugo?
Ti so precej cenejši od Boschevih. Imaš izkušnje s temi MAF-i?Damijan napisal/-a:Meat&Doria ali pa Hofer.
Sem danes preveril in je ista napaka kot prejšnič (P1177 in P1178). Bom drugi mesec menjal MAF in bomo videli, če bo napaka odpravljena.alfa_samec napisal/-a:Javi isto napako ali katero drugo?
Se strinjate s tem. Lambda je stara okoli eno leto, kupljena nova Bosch. Morda reskirat 100€ na MAFMAF reads how much air is comming into the engine. O2 reads how much is left in the exhaust. If the MAF is old it may give false readings to the O2 and the ECM usualy throws a code of a bad O2. The reason is the ECM sees the MAF as "working" even if is not working very well, ECM only gives you a code when the MAF does not work at all, again, good reason to get a new one.
