Giulia: Testi in Splošno
Toolox
Prispevkov: 1025
Giulietta Super Veloce
Gtv V6 Tb
166 V6 3.0 Super
=D> =D> =D> =D>
To pa je taprav stric :D
164 3.0 V6 12V
159 2.0 JTDm
Gtv 2.0 V6 Turbo
166 3.0 V6 24V
alex146
Prispevkov: 1780
Dobre fotke
https://avto.over.net/clanek/iztok-in-a ... 1517382485" onclick="window.open(this.href);return false;
alfafil
Prispevkov: 4576
Kraj: maribor
Torej, dizle iz zaloge, glede na to, da bodo že kmalu zastareli, nima smisla kupit. Kaj pa TB 200? Če sploh je kakšna na zalogi pa še z podobnim popustom kot dizel.
b_bay
Prispevkov: 330
Vozilo: Alfa Romeo 159 2.0 JTDM 170KM
A vi dejansko imate 40k+ za nov avtomobil, ki tega denarja niti slucajno ni vreden?
bacco979
Prispevkov: 79
Pridružen: Po Jun 03, 2013 7:34 am
Vozilo: 2014 Giulietta 2.0 16v
b_bay napisal/-a:A vi dejansko imate 40k+ za nov avtomobil, ki tega denarja niti slucajno ni vreden?
Kateri avto pa je vreden po tvoje 40k? Tolk danes stanejo še malo bolje opremljene Škode.
Prispevkov: 4995
Glede razlik med 200 in 280 konjskim bencinarjem (iz tujega foruma):
MacGeek napisal/-a:All 2.0L GME engines have two cooling circuits.
As for hardware differences, it depends.
The 200hp engine with code "0" (cars with MVS codes 620.*R0.0) is, hardware-wise, identical to the 280hp engine with code "1" (MVS codes 62[0,1].*[R,A]1.*).
In late 2017, a new version of the 200hp engine was introduced, with code "9" (MVS codes 620.*R9.0). This version does not have any of the hardware necessary for EGR.
Razlike so tudi drugje - primerjava prvotnih 200 konjskih različic s kasnejšimi:
The first 2.0 t 200bhp are coming through built to 280 spec. Currently on your engine the egr, intake lambda probe and heat exchanger for the heating function on the intercooler are present but not used by the eco, they are mapped out. Also the pistons are weight classified, again only a thing that will be on the 280 version. So the only difference on your engine is purely a map! They will be changing the 200bhp in due course when the new plant is up and running
alfafil
Prispevkov: 4576
Kraj: maribor
Saj najdeš kakšno za manj kot 30k tudi, novo.
Grilzz
Prispevkov: 1700
Pridružen: Ne Jan 18, 2004 7:57 pm
Kraj: Lj
Bo v giuliji 1.3?
Po eni strani malo romanticno, po drugi pa malo malo.
https://motori.virgilio.it/auto/alfa-ro ... bo/108623/" onclick="window.open(this.href);return false;
"Anyone who has driven anything from an Alfa 75 to an old Giulia Super or GT Junior will know their real magic lies in the way they come alive in the corners."
Alan
Prispevkov: 4561
a mondeo 1.0 je pa ok :mrgreen:
Cifre so cisto lepe in avto bo sel sigurno dobro.
Modras
Prispevkov: 651
Pridružen: Po Maj 27, 2013 11:03 am
Ja žal so nizke kubature danes v modi in narejene z namenom, da zadeva čimprej crkne.
Meni gre na smeh in bi me bilo sramota imeti tako majhen motor v tako velikem in povrh športnem avtu.
A tebe, ne?
Grilzz
Prispevkov: 1700
Kraj: Lj
Niti ne.
Giulia 1300 je bila pojem.
Edit.:
Sploh ce bo s ceno pod 150km dizelco.
Prispevkov: 4995
Ker s septembrom prihajajo nove euro norme, bosta Giulia in Stelvio dobila nekaj motornih nadgradenj.
2.0 Turbo motor dobiva filter trdih delcev, 2.2 dizel pa SCR katalizator.
Medtem kot pa 2.9 V6 iz Quadrifoglio modelov vpeljuje zanimivejšo oz. kompleksnejšo rešitev ki ne vsebuje filtra trdih delcev.
Motorju so dodali še 6 injektorev s klasičnim vbrizgom, torej pred ventili. Na ta način so dosegli manjši izpust trdih delcev in NOx-ov, dodaten plus tega pa je preprečevanje nabiranja saj na ventilih (carbon buildup).
Tako, da bo ta motor sedaj imel 12 injektorjev - 6 z direktnim vbrizgom in 6 z vbrizgom pred ventili.
Še vedno pa so zelo leni - edina novost pri opremi je gretje zadnjih sedežev - Giulia Quadrifoglio pa je že Aprila dobila 5 sedežev in deljivo zadnjo klop; medtem ko je Audi pri A4-ki (ki je bila predstavljena istega leta kot Giulia), že naredil prvi face-lift, FCA pa raje Giulio drži na ravni dodatne opreme iz leta 2010... Ne vem kaj jim je tako prekleto težko, dodati par kosov opreme iz Maseratija, da bi prišli vsaj na isti nivo kot ostale znamke v tem segmentu. Mah...
Kruta realnost je da so 5 ali več let za konkurenco.
Mrtvega časa, ki so ga izgubili med ukinitvijo 159 in začetkom proizvodnje Giulie ne bo enostavno nadoknaditi.
Predvem pa ne na način kot so si ga zastavili.
Prispevkov: 2831
Kaj je spremenjeno v smislu izboljšanja zvočne izolacije kabine? Točnen datum izboljšanja?
Zopet v kontaktih z AT pa skladno s starimi praksami nobenega odgovora, ponudbe,....
Je bela (nova, 1km,...) že z izboljšano izolacijo?
Prispevkov: 2831
ROBERTH napisal/-a:Kaj je spremenjeno v smislu izboljšanja zvočne izolacije kabine? Točnen datum izboljšanja?
AT... zopet nobenega odziva (na dveh koncih), tu no ping, me & Giulia bad carma!
Bawarc je prodan, grem pa iskat kaj drugega...... :-)(
