zdravc napisal/-a:zakaj bi mislil da je enako dolga? ogrodje je enako, ampak vpetje vzmetenja je drugacno, tako je tudi medosna malo daljsa. temu drugace v anglescini pravijo floor pan, in je glavni/nosilni element strukture avtomobila.
osnova ima enak izvor, cetudi je zunanja oblika drugacna.
recimo fiat coupe in 145 imata to strukturo skoraj do pikice enako.
medosne sem napisal, da je jasno da sta bravo/brava in 145/146 na povsem enakem podvozju.
kar pa za 156 nisem pisal. beri zgoraj.
lahko pa še enkrat preberete tole, in tokrat bolj pozorno:
Tipo's derivatives
Fiat�s platform sharing strategy reached its peak during the Tipo era. Fiat Tipo was launched in 1988 as Fiat�s Golf-beater. Its simple front MacPherson struts / rear trailing arms platform was soon found sharing with a dozen models in the group. Here is the complete listing (loaded from my memory) - Fiat Tipo, Fiat Tempra, Lancia Dedra, Lancia Delta, Alfa 155, Alfa 145/146, Fiat Brava/Bravo/Marea, Fiat Coupe, Fiat Punto, Alfa GTV/Spider, Alfa 156 and Lancia Lybra.
The earliest derivatives did not changed much the hard points position, hence essential dimensions. These include today�s 145/146, Delta and Brava/Bravo/Marea. They differ from each other by packaging, styling and suspension tuning. Fiat and Lancia share the same engines and transmission. Alfa got modified 4-cylinder engines (e.g. with twin-spark added) and sportier suspension setup.
146 is a 145 with longer boot, although both of them are hatchback.
Brava is the 5-door version of the 3-door Bravo. Marea is the 3-box saloon version. Marea Weekend is an estate.
Alfa GTV / Spider, Alfa 156 and Lancia Lybra received much more development. GTV / Spider has multi-link replaces strut as rear suspension. The front still rides on strut. On the contrary, 156 has the front suspension changed to double-wishbones while using struts at the rear. Lybra remains strut in front but introduces a new GLA (Guided Lateral Arm) rear suspension. Again, Alfa has its own engines (including V6s) while Fiat and Lancia share the same engines. Alfa even got advanced transmission such as Selespeed. Although there are still a lot of common components sharing among them, it is no longer adequate to call these cars as sharing platform.
ce koga zanima in ne zna anglesko naj pove, pa bom povzel.
edit:
na pepsijev edit: za 147 nimam podatkov, sem si jo pa v živo natančno ogledal na dvigalu spodaj, in se ne razlikuje od 156ke.
