Hvala!Alfaspider napisal/-a:Daš obroček na ON, nato se pelješ hitreje kot cca. 30km/h in obrneš obroček za nastavljanje hitrosti naprej ali nazaj in to je to. Včasih zna štekati kakšno stikalo na pedalih sklopke ali zavore in zato noče vklopiti tempomata.
Iz eLearna (pa se mi niti pod razno neda prevajat).To activate the cruise control:
turn the ring nut switch to the ON position
set the desired speed (> 30 kph)
turn the SET ring nut towards the (+) or (-) sign
release the accelerator pedal.
The cruise control can operate in the entire permissible engine range for versions with either manual or automatic transmission.
The cruise control does not operate:
in 1st gear or reverse where there is a manual gearbox
in P, N or R where there is automatic transmission
below 30 kph.
The action of turning the ring nut switch to the OFF position cancels any speed previously set.
A warning light in the control panel, activated by the injection control unit, indicates whether the system is operating or not.
For safety reasons, the A.S.R. (Anti-Slip Regulation) function has priority over the cruise control.
When the operation of the A.S.R. is over,, the cruise control function is automatically reactivated at the speed set.
Manual disengagement of cruise control
The driver can disable the cruise control by:
the turning the switch to the OFF position
switching off the engine
operating the brake or clutch pedal (the last speed is memorized and can be recalled by pressing the RECALL button)
operating the automatic gear selector lever in position P, N, R (the last speed is memorized and can be recalled by pressing the RECALL button)
vehicle speed below 30 kph (the last butterfly angle remains memorized and the speed can be recalled by pressing the RECALL button)
operating the accelerator pedal
In this case, the cruise control remains on, but the management of the accelerator pedal is allowed.
Automatic disengagement of the cruise control
The system automatically switches off the cruise control if there is:
acceleration due to a steep descent
deceleration due to a steep incline
operation of the gear selector lever without using the clutch.
The system automatically switches the cruise control off in the following failure conditions:
sensor signal failure which implies the desire of the driver to alter the driving conditions:
accelerator pedal potentiometer
clutch switch
brake switch
brake lights switch
cruise control RECALL button
cruise control SET ring nut
failure with the other system sensors or components:
injection/ignition control unit
engine rpm sensor
vehicle speed
automatic transmission selector lever position (where fitted)
a failure in the control system or the components which lead to an engine malfunction:
turbocharger sensors/actuators (where fitted)
motorized butterfly casing
air flow meter
engine ignition
injectors
RCL=recallfiatseba napisal/-a:kaj pomeni gumb RCL na tempomatu? Čemu služi?
Da se temopat spet nastavi na prej nastavljeno hitrost. Se pravi če si prej vozil 160 s tempomatom, in si bil primoran bremzat, potem ko je AC spet prosta pritisneš RCL in avto spet pospeši nazaj do 160.fiatseba napisal/-a:kaj pomeni gumb RCL na tempomatu? Čemu služi?
