ce mene vprasas bo kvaliteta slike zelo porazna.... premalo pixlou...
Ampak tu je napaka - video sync (pin 17 na črnem konektorju) je treba vezat na pin 19 v scartu (ne na 20).Hi everybody,
yesterday i made first succesful test of my own videointerface. You can see it here:
http://www.sweb.cz/honda.vfr
How to do it ?
First download and print the documents.Then:
The pin no.5 on the green 26pin connector must be connected to the ground (ICS chassis) to switch the ICS to TV mode.
Everything you need to do then is to take some SCART to SCART video cable,dissasembly one SCART connector and solder pins on the requested wires (just see the documents). It`s necessary to connect ground signals for red, green and blue to one wire and then to pin 3 on the black connector. Next important wire is wire 20 on scart connector (composite video in), it must be connected to pin no.17 on ICS black connector (to sync the picture). Then just connect other wires for red, green, blue and audio and it`s done.
Be sure to have regular RGB/Scart output on your DVD player, DVD with composite video out with simple reduction to SCART will not work ! Or use some converter.
Good luck !
