Morjo bit, drugače v četrtek ne morem na PagGregson007 napisal/-a:hello, a bojo gume do vikenda ??![]()
l.p.
Setting it to 0deg at the rear will make it very loose at the rear, toe-out at the rear will lead to very sudden oversteer.
Rear toe-in for a 147 should be 0deg29' +/- 9' (0.48deg +/- 0.15deg)
At the front the std 147 setting is toe-out 0deg17' +/- 8' (0.28deg +/- 0.13deg), but setting to 0deg (as with 156 sportpacks) usually brings more even tyre wear.
Tole sem zasledil... večina folka ki je nastavila spredaj stekanje proti 0° pravi da se obraba notranjega roba gum močno zmanjša. Verejtno imajo zato Sportpack 156 vse spredaj stekanje na 0°, ker ima ze standartno znizano podvozje.I've just refound an updated spec:
147:
Front: Toe-Out 0deg18' +/- 5'
Rear: Toe-In 0deg27' +/- 9'
156:
Front: Toe-Out 0deg9' +/- 5'
Front (Sportpack): 0deg +/- 5'
