Piki napisal/-a:Da ne bi bilo moje življenje z Alfo slučajno premalo pestro, se je pojavil problem z daljinskim odklepanjem in zaklepanjem. Danes sem avto pripeljal z manjšega ličarskega popravila, ko sem hotel odkleniti vrata, daljinec ni prijel. Sprejemniku na servisu, ki mi je avto predal nisem šel omenit, mislil sem, da spet malo nagaja, včasih se je zgodilo, da sem moral večkrat pritisniti, da je odklenilo. Potem sem pomislil, da je slaba baterija, ali pa je kaj narobe z ključem. Doma sem potem probal z rezervo in presenečenje ; tudi ta ne dela !! Če je to kaj povezano z omenjenim servisem ne vem, je pa dejstvo, da je prej vse delalo normalno, pa tudi oni bi to morali opaziti. Pa niso nič rekli. Vsekakor jih bom jutri malo pobaral. Potem sem se spomnil, da je bila tudi klima izklopljena, sem jo moral vklopiti s srednjim gumbom/displayem. Ne vem ali je to kaj povezano, je pa čudno. Z ključem odklepa in zaklepa normalno, tudi z vžigom ni problema. Ima kdo kakšno idejo, izkušnjo ?
Emergency starting procedure
The emergency starting procedure makes it possible to start up the engine if there is a problem in the Code system (Code control unit faulty, keys unusable, etc.), i.e. if the engine control unit has not received the go ahead for starting from the Code control unit.
This operation is useful for starting up the engine and driving the vehicle to a Service Centre to have the fault repaired.
This procedure can be carried out using the Examiner or - only in emergencies - using the accelerator pedal:
By acting on the accelerator pedal, the emergency code is transmitted to the injection control unit through the signal detected by the butterfly valve.
Carry out the following operations in the order given:
1. Read the emergency code on the Code Car.
2. Turn the key to the ON position; press the accelerator pedal and keep it pressed.
The injection failure warning light should come on for 4 seconds, then go out briefly (150 ms.) and come on again for another 4 seconds.
3. When the warning light goes out, release the accelerator pedal.
4. When the pedal is released, the warning light should start to flash (at a frequency of 0.8 Hz).
5. After a number of flashes equivalent to the first figure of the code on the Code Card, fully depress the accelerator pedal and keep it depressed.
6. The injection warning light should come on again for 4 seconds and then go out to indicate that the first figure has been accepted.
7. When the warning light goes out, release the accelerator pedal.
8 When the pedal is released, the warning light will start to flash again as before (frequency 0.8 Hz).
9 After a number of flashes equal to the second figure, press the accelerator pedal; the warning light should come on for 4 seconds to indicate that the second figure has been accepted.
10 Repate the above for the other figures in the emergency code.
11. When the pedal is released after the last figure has been accepted, the warning light should flash for around 4 seconds at twice the frequency (1.6 Hz) to indicate that the entire code has been accepted. If, on the other hand, the warning light remains on, this means that the code has been rejected.
12. If the code has been accepted, start up if the engine; if this is not the case, turn the ignition to the OFF position and try the operation again.
