1.The larger intercooler was a gift for my birthday from some friends from our Alfa Club here in Bulgaria...the cooler is from Renault Master (bus) 2.8diesel.
Then I paid around 200Euro to make all the pipes need it to connect the cooler and to change the cooler inlet/outlet pipes. Most of the pipes are from steal (not samco) so that way we are reducing the turbo lag from the longer piping to a minimum. There is a thread around AO forum with pictures of how the cooler is fitted and all the pipes.
2. Catalytic converters are: The front one is a kind of a "harder" task you need to remove the turbo and ones you have the front catalytic converter you need to cut its tubing in a way so you can weld it back together after getting rid of the cat. inside. otherwise you will end up making a whole new piping from the turbo to the exhaust pipe.
Rear main cat. is a simple task....cut the tube and replace it with straight pipe...keep the old cat. somewhere safe in case it needs to get back ever again.
3. The free-flow back box (eg. sport exhaust) was custom made for my car, and it cost me less then 200Euro.
4. BMC-CDA 70-150 a get it from a friend of mine from the Greek Alfa Club. A new one is around 250Euro....BMC suggest placing the smaller filter NOT 70-150 because you won't be able to fit it IF YOU keep the original Intercooler.
Is it worth the 250Euro, in my opinion YES it IS....on a tuned car! It lets a lot more air inside the engine compared to the factory fitted filter or a replacement one. There is a thread around AO with a problem I had after fitting the filter...I was getting boost leves of almost 2.4Bar!!! compared it to the 1.5Bar I am running with the current remap...factory 1.2...old map 1.4Bar
The problem was the electric valve (solenoid) that controls the turbo...it was faulty and it wasn't able to open the vanes in time to prevent the turbo pressure increasing so much. With the factory filter that problem was not there...
So yes the BMC-CDA is doing what BMC is claiming.
ps: I would NOT go for a mushroom filter, it lets a lot of dirt inside your engine....so it will kill the engine quickly, and will damage the MAF.
5. My first remap was done by
www.DigitalTuning.ch for 550Euro...there are extremely good tuners and from what I have seen for a few years maybe are the company to go for from all of Europe.
My second map which takes into account all hardware changes I have done was again done by DigitalTuning Swiss. They have created a whole new map for my bella, not just increase a few thing here and there. I can see that, because I have the software and the hardware to remap my car by myself BUT I leave that to DigitalTuning as their maps are way way better then anything else I have come across.
KEEP in mind one thing, I am tuning my car as a daily driver!!! I can get even more BHP and better performance out if it if I want to, but I have to keep the things withing certain limit.
Any questions are more then welcome.
ps: I am washing my BMC-CDA now...so I will see the full performance tomorrow, and soon I am planing to have the car dynotested so I can have the exact figures for the BHP and NM.
