Povečanje moči JTD-u / Chip tuning / Čipiranje
Izgled Alfic, povečanje moči
Bearex
Prispevkov: 2223
Kraj: Štore
No če pa bi res rad tuniral, pa še opis kako je prišel član AO foruma do naslednjih cifer:
I have about 170bhp and 400NM out of my 8v JTD.
1. larger FMIC
2. Both of the catalytic converters are gone
3. Free-Flow back box is fitted
4. BMC-CDA 70-150 replaced the original Air-filter box
5. New remap to take into account the changes made
Pa še podrobnejši opis:
1.The larger intercooler was a gift for my birthday from some friends from our Alfa Club here in Bulgaria...the cooler is from Renault Master (bus) 2.8diesel.
Then I paid around 200Euro to make all the pipes need it to connect the cooler and to change the cooler inlet/outlet pipes. Most of the pipes are from steal (not samco) so that way we are reducing the turbo lag from the longer piping to a minimum. There is a thread around AO forum with pictures of how the cooler is fitted and all the pipes.
2. Catalytic converters are: The front one is a kind of a "harder" task you need to remove the turbo and ones you have the front catalytic converter you need to cut its tubing in a way so you can weld it back together after getting rid of the cat. inside. otherwise you will end up making a whole new piping from the turbo to the exhaust pipe.
Rear main cat. is a simple task....cut the tube and replace it with straight pipe...keep the old cat. somewhere safe in case it needs to get back ever again.
3. The free-flow back box (eg. sport exhaust) was custom made for my car, and it cost me less then 200Euro.
4. BMC-CDA 70-150 a get it from a friend of mine from the Greek Alfa Club. A new one is around 250Euro....BMC suggest placing the smaller filter NOT 70-150 because you won't be able to fit it IF YOU keep the original Intercooler.
Is it worth the 250Euro, in my opinion YES it IS....on a tuned car! It lets a lot more air inside the engine compared to the factory fitted filter or a replacement one. There is a thread around AO with a problem I had after fitting the filter...I was getting boost leves of almost 2.4Bar!!! compared it to the 1.5Bar I am running with the current remap...factory 1.2...old map 1.4Bar
The problem was the electric valve (solenoid) that controls the turbo...it was faulty and it wasn't able to open the vanes in time to prevent the turbo pressure increasing so much. With the factory filter that problem was not there...
So yes the BMC-CDA is doing what BMC is claiming.
ps: I would NOT go for a mushroom filter, it lets a lot of dirt inside your engine....so it will kill the engine quickly, and will damage the MAF.
5. My first remap was done by www.DigitalTuning.ch for 550Euro...there are extremely good tuners and from what I have seen for a few years maybe are the company to go for from all of Europe.
My second map which takes into account all hardware changes I have done was again done by DigitalTuning Swiss. They have created a whole new map for my bella, not just increase a few thing here and there. I can see that, because I have the software and the hardware to remap my car by myself BUT I leave that to DigitalTuning as their maps are way way better then anything else I have come across.
KEEP in mind one thing, I am tuning my car as a daily driver!!! I can get even more BHP and better performance out if it if I want to, but I have to keep the things withing certain limit.
Any questions are more then welcome.
ps: I am washing my BMC-CDA now...so I will see the full performance tomorrow, and soon I am planing to have the car dynotested so I can have the exact figures for the BHP and NM.
Zdaj, če si pa ti pripravljen it v to in razkirat mašino, je pa drugo vprašanje, vsekakor pa je najbolje, da si avto najprej kupiš, ga pelješ k enemu zelo dobremu serviserju, da ti oceni realno stanje avta (no ja, bi blo dobro to že pred nakupom opravit) in pol razmišljat dalje.
Kaj me moti na moji Alfi?
Pravzaprav nič drugega kot zavistni pogledi lastnikov drugih znamk, ki jim je Alfa všeč, a si je ne upajo imeti.
alro
Prispevkov: 2700
Se mi ni dalo vsega brat, ampak italijan na 147VirtualClub je potegnu iz 116KM 147 -ke če se ne motim na zadnji meritvi 241 KM :loljeah: . Mislim da je v predelavo zabil blizu 10.000€......aja, na koncu je ribnila ](*,) .
Če sem prav razumel bi ti rad prišel na 145 KM :?: :-k Zakaj vse to kompliciranje ? Npr. uporabnik Creed ima 147 -ko čipano na cca. 145 KM.
cresh
Prispevkov: 139
Pridružen: Ne Avg 17, 2008 7:05 pm
Kraj: Litija
sej ni panike dobit 200+, ampak je kle potlej problem o vzdržljivosti. Sej ti lohka samo elektronko nabije do konca kolikor gre pa je, sam vprašanje za koliko časa. Drgač un zgoraj je neki tazga naredu kar sem jst mel v mislih, simpl, brez odpiranja mašine pa da imaš še normalen daily drive.
alfafil
Prispevkov: 4576
Kraj: maribor
-če hočeš več moči,čipaš avto za nekaj sto evrov in to je to
-še bolj enostavna in cenejša varijanta je tuning box,zdaj pa je od vsakega posameznika odvisno kako se bo odločil
-eno in drugo je poseg v motor,tveganje je tvoje,pametovati kaj je boljše,je samo prepričavnje,kdo je bolj "pravilno" ravnal
-močne firme ti dajo garancijo na motor in menjalnik (proti ustreznemu plačilu,seveda) in zakaj :?: ,ker je tveganje,še posebaj če gre za nov avto, manjše,firma pa ima dovolj zasluženega denarja,da krije stroške,ki so procentualno zanemarljivi,glede na zaslužek :wink:
Creed
Prispevkov: 4301
alro napisal/-a:Se mi ni dalo vsega brat, ampak italijan na 147VirtualClub je potegnu iz 116KM 147 -ke če se ne motim na zadnji meritvi 241 KM :loljeah: . Mislim da je v predelavo zabil blizu 10.000€......aja, na koncu je ribnila ](*,) .
Na 141 KM :wink:
greh29
Prispevkov: 201
Pridružen: Če Nov 29, 2007 5:00 pm
Ja,2,4 20V pa res ni problema odpret na 200+...Jaz jo imam že lep čas odprto na 215KM,pa gre kot raketa,je pa res,da se držim treh zlatih pravil in to je to!
gregork
Prispevkov: 596
Pridružen: Po Sep 29, 2008 2:10 pm
Kraj: Bohinj
Kje pa si jo uštimov? greh29
In v kolkem času to uredijo saj imam jaz tud 2,4 m-jet 20V.
AR ruls
greh29
Prispevkov: 201
Zadevo sem uštimal v Austriji v Gradcu pri firmi Tuner,www.tuner.at,sam postopek pa traja cca.1uro.Zdaj pa ta ista firma deluje cca.vsakih 14 dni tudi v MB,če je v Sloveniji dovolj interesentov za čipanje.Pridejo mojstri iz Austrije pa čipnejo 5-10 avtomobilov.Seveda pa se je treba prej vse dogovorit.Najbolje bo,da jim pošlješ mail in svojo telefonsko,pa te bo poklical njihov referent za Slovenijo.Jaz sem bil v še v Gradcu.Z tuningom zelo zadovoljen,avto je neprimerno močnejši,navora je 450NM,in vleče že pri1400!!!obratih!Poraba pa se je zmanjšala za cc.05-1l/100km.Delam samo redne servise in to je vse!
Pri naslednjem avtu(tega bom imel še verjetno 3-4 leta)bom zadevo defenitivno in brez dvoma ponovil!Dokler ne probaš,sploh ne veš kakšna je lahko razlika.
gregork
Prispevkov: 596
Kraj: Bohinj
Koliko pa pride nadgradnja?
AR ruls
greh29
Prispevkov: 201
Jaz sem plačal 450€,imam pa s tem pri naslednjem tuningu pri njih 150€ popusta.Dobil račun in 3 leta garancije na tunning.
gregork
Prispevkov: 596
Kraj: Bohinj
Hvala.
Če bom še kaj rabu te zvrcnem. 8)
AR ruls
Cuore Sportivo
Prispevkov: 2145
greh29 napisal/-a:Zadevo sem uštimal v Austriji v Gradcu pri firmi Tuner,www.tuner.at,sam postopek pa traja cca.1uro.Zdaj pa ta ista firma deluje cca.vsakih 14 dni tudi v MB,če je v Sloveniji dovolj interesentov za čipanje.Pridejo mojstri iz Austrije pa čipnejo 5-10 avtomobilov.Seveda pa se je treba prej vse dogovorit.Najbolje bo,da jim pošlješ mail in svojo telefonsko,pa te bo poklical njihov referent za Slovenijo.Jaz sem bil v še v Gradcu.Z tuningom zelo zadovoljen,avto je neprimerno močnejši,navora je 450NM,in vleče že pri1400!!!obratih!Poraba pa se je zmanjšala za cc.05-1l/100km.Delam samo redne servise in to je vse!
imaš tudi kakšen graf?
(gledam graf od 156 v6, ki ima 160nm že pri 1500rpm. ni slabo 8) )
http://www.rototest.com/performance-gra ... &Visitor=2
cuore sportivo147
Prispevkov: 63
Pridružen: Po Apr 28, 2008 12:17 pm
Vem da vas je veliko, ku vas je dalo čipat avto in da ne odpiram nove teme bi rad vprašal tiste ki so že čipali za nasvet.Bil sem pri RSR-ju in pač poizvedel mal kako to gre.sem pa mal skeptičen da nebi pol ta stvar šla po gobe čez mesec ali 2.ribnil mi je že 2.0 TS ampak to je druga pesem.mene je sam strah da nebi blo s to pol isto.avto mam nekje 4 mesece.naredil sem 10000 kilometrov že z njim menjal olje in vse filtre pač normalen servis in zdej lepo pelje naprej.v teh kilometrih ni popilo kaplje olja in in tudi drugih znakov da bi blo kaj narobe z motorjem al čemerkoli drugem ni.pač če dam gas podkadi ampak to je jtd.tiste ki ste že čipali prosim za nasvet naj čipam al ne.in če se kak najde da mu je vse skupaj ribnilo naj tudi pove svojo stran.hvala!aja je pa navaden JTD 116ks in prevoženih 90000k.
Creed
Prispevkov: 4301
Cipni :D
q_verde
Prispevkov: 485
Pridružen: Pe Apr 02, 2004 9:02 am
Kraj: celje
Creed napisal/-a:
Cipni :D
x2
za 116KM ni problema, ker sklopka zdrzi. masine so pa itak pregovorno >>neunicljive<<. pri 140/150KM zna biti problem sklopka. ne prenese ogromnega prirastka navora, ki ga dobis s cipanjem. pri 116KM teh problemov ni.
crna alfa 145 1,6 16V TS (bivsa '00)
rdeca 156 M-JET (bivsa '05)
siv bmw 320d e91 ('06)
