Iščem gorsko kolo za mešano vožnjo, asvalt, makedam, gozdna vožnja...morda ob priliki še kakšen spust z kakega hriba "downhill"
Predvsem me zanima na kaj bi bilo dobro biti pozoren pri okvirju ki je osnova dobrega kolesa, bi bilo bolje v tem cenovnem rangu se odločati za diske...ali je prepoceni kolo, da bi zadeva laufala tko kot mora dolgo časa...predvsem iščem dobro vzdržljivo kolo, ki bi preneslo marsikaj...
Zaenkrat imam ogledane naslednje:
Scott aspect 20
Sizes
XS,S,M,L,XL,XXL
Weight
13.90 kg
30.62 lbs
Frame
Aspect Hydroformed D.B.
Alloy 6061
Performance geometry
Integrated headtube
Fork
Rock Shox Dart 2
with Lockout
100mm travel / reb. Adj.
Headset
Ritchey Logic OE integ.
Derailleur (Rear)
Shimano LX
RD-M581
27 Speed
Derailleur (Front)
Shimano Deore
FC-M510 / 31.8mm
Shifters
Shimano Deore SL-M530
R-fire plus 2
w/gear indicator
Brake Levers
Shimano BL-M485
Brakes
Shimano BR-M485
Hydr. Disc
Crankset
Shimano
FC-M442, black
44x32x22 T
BB-Set
Shimano BB-UN-26
68/113mm
Handlebar
Scott Comp
620mm, black
20mm rise 8°
H'stem
Scott Comp
JD-ST33 AS
Pedals
Wellgo
LU-998-S
Seatpost
Scott Comp
HL SP-209 / 31.6mm
Seat
SCT-10 SL Aspect 08
Hub (Front)
Scott Disc Comp CL
Hub (Rear)
Shimano FH-RM 65-CL
Chain
Shimano CN-HG53
Cassette
Shimano CS-HG50-9
11-32 T
Spokes
14 G, stainless
Rims
Alex TD-24 Disc 32H
Black
Tires
Scott OZON
26 x 2.0
27TPI
CENA: 800 ojrov
Stevens S6 pro
Front fork SR Suntour Axon E, 80mm, Lockout, aluminium shaft*
Headset FSA Ahead Integrated Mod. 11, 1 1/8"
Drivetrain
Crankset Shimano Deore M530 Hollowtech, 44-32-22
Bottom bracket Shimano ES30 Octalink 113mm
Derailleur r Shimano Deore M530
Derailleur f Shimano Deore M531
Chain Shimano HG53
Cassette Shimano HG50.9 11-32
Pedals MTB Alu Dual Side
Wheelset
Hubs r Shimano Deore M530
Hubs f Shimano Deore M530
Rims Rigida Shpinx with eyelet, CNC side 36 L
Spokes stainless steel 2.0mm
Tires Continental Vapor Pro 26x2.1" collapsible
Cockpit
Handlebar Oxygen Driver DB 580mm
Stem Oxygen Driver 25.4mm
Saddle Oxygen Velocity
Seatpost Oxygen Driver 350mm
Shift-Brakelever Shimano Deore M530 Dual Control
Brakes Shimano Deore M530 V-brakes
Data
Weight 12.1 kg
Frame tubing Aluminium 7005DB t-wall
Sizes 15, 18, 20, 22"
Color(s) Anthracite Silvergrey
New 2006
Fork Lockout function, aluminum shaft, higher-end modell
Components New Deore with Dual Control shifting system and Deore Hollowtech crank...
Frame New frame design, Stevens Dropouts
Cena 750 ojrov
KTM ULTRA LINE
OKVIR: ALUMINIJ 6061 triplebutted
VELIKOST: 43 48 53
VZMETENJE: SUNTOUR XCR LO 100 MM
OPREMA: 27P SHIMANO LX/DEORE
ZAVORE: SHIMANO DEORE V BRAKE
OBROČI: AMBROSIO KEBA
TEŽA: 13.3 Kg
Cena 700 ojrov
Mnenja, predlogi za kaj X ??
