hello my name is peter 27 and I've just joined your club in slovenija also the reason I was looking who miss a two din car radio built didst in facelift Alfa Romeo 156 because in the Netherlands there is nothing to get from so I went searching on the forum and saw you standing photo doog in slovenija and so I can send a message to you because I would like to make the same as you've made in your alfa Romeo 156 now I sit with a problem that is the bottom of the dashboard with the metal strip in the dashboard where the heater operating normally on stuck because it was a 2 din car is 7 inches Kenwood must all things now I know how it all up in the dashboard does that the problem is not but I'm on the bottom that metal strip in the dashboard and would like to know from you doog how you've done that with the heater operation and hope that the mine can can make out empty or a drawing how exactly have I done saw that they had the heater panel had done down made in the console or the clocks down into the console in building but I thought of you have I made the most is my email address there to put as you my e mail I will send pictures to do it because I think it does not go through the forum can send along so I thank you may peter 27 email [email protected]
zdravo doog Imam vprašanje o facelift Alfa Romeo 156 bj 2004 I zgradili v armaturno ploščo imam vprašanje o kovinskem traku na dnu, kjer je kontrola grelec pride, da ste pritrjen kovinski trak nižje dol in konzole prestregla vrh, kot če vas moj blagoslov, ki bi lahko, bi jo cenili, kako si to hvala peter 27
