2 DIN radio - AR 156
Izgled Alfic, povečanje moči
_doog_
Prispevkov: 174
Pridružen: Sr Maj 06, 2009 9:56 pm
Sm slučajno na netu naleteu na 2din radie v alfah 156 in me zanima je kdo že kj ustvarju....
tako naj bi zgledal v moji alfici
mau sm se poigrau v paintu
GS
Prispevkov: 18
Pridružen: Ne Dec 13, 2009 8:29 pm
Res hudo zgleda... 8)
_doog_
Prispevkov: 174
Vem. Bomo probal kj ustvart..
bom najdu s kšne razbite armaturo.... :)
Takole zgleda v moji 159-ki:
Je pa pri 156-ki potreben malo večji poseg, ker moraš enoto za klimo prestaviti stopnjo nižje.
_doog_
Prispevkov: 174
Zelo lepo =D>
Kako si pa ozadje prštimu :?:
Obstaja opcija shranitve ene slikce...
MrPetek
Prispevkov: 576
Kraj: Gorišnica
Si se že lotil tega projekta?
Prispevkov: 4995
V 159-ki zgleda v redu, v 156-ki pa ni za nikamor.
_doog_
Prispevkov: 174
Na fl armaturki je men kr ušeč :)
Jst se nism še lotu tega, kjer nism se dobu nobene pocen konzole take cene so mi prbijal joj [-X
Peter27
Prispevkov: 2
Pridružen: Po Jan 09, 2017 11:56 am
hello my name is peter 27 and I've just joined your club in slovenija also the reason I was looking who miss a two din car radio built didst in facelift Alfa Romeo 156 because in the Netherlands there is nothing to get from so I went searching on the forum and saw you standing photo doog in slovenija and so I can send a message to you because I would like to make the same as you've made in your alfa Romeo 156 now I sit with a problem that is the bottom of the dashboard with the metal strip in the dashboard where the heater operating normally on stuck because it was a 2 din car is 7 inches Kenwood must all things now I know how it all up in the dashboard does that the problem is not but I'm on the bottom that metal strip in the dashboard and would like to know from you doog how you've done that with the heater operation and hope that the mine can can make out empty or a drawing how exactly have I done saw that they had the heater panel had done down made in the console or the clocks down into the console in building but I thought of you have I made the most is my email address there to put as you my e mail I will send pictures to do it because I think it does not go through the forum can send along so I thank you may peter 27 email [email protected]
Prispevkov: 7954
Peter please type using punctuation marks otherwise it is VERY hard to understand what you are saying.
Doog did not make this modification as he was writing his post, he just created a preview of how it could look like.
Peter27
Prispevkov: 2
zdravo doog Imam vprašanje o facelift Alfa Romeo 156 bj 2004 I zgradili v armaturno ploščo imam vprašanje o kovinskem traku na dnu, kjer je kontrola grelec pride, da ste pritrjen kovinski trak nižje dol in konzole prestregla vrh, kot če vas moj blagoslov, ki bi lahko, bi jo cenili, kako si to hvala peter 27
[email protected]
