Ultrazvočno čiščenje
ce je se na toplo vodo pa sploh odlicno, tudi sam sem s takim cistil
spartan
Prispevkov: 629
Pridružen: Če Jul 29, 2010 2:41 am
Kraj: Slovenska Bistrica
Koliko je pa dela s kolektorjem (demontaža in remontaža vseh sklopov)?
Apophis
Prispevkov: 313
Pridružen: So Jan 02, 2010 12:45 am
Kraj: Gorenjska
El Barto napisal/-a:@Overs[t]eer
Vsakič ko ta postopek berem, crkam od smeha ... =D> :rofl: :rofl:
Kremenčev pesek v sesalni kolektor iz auspuha pa frnikule! :loljeah: :loljeah: :rofl:
jtd-M 20V
kosir1234
Prispevkov: 3687
Overs[t]eer napisal/-a:Mogoče bi pa tale metoda, ki jo uporabljajo Hondaši za portanje kolektorjev bila uspešna... (kopirano z audi foruma, kjer to žal ne deluje, je pa lepo opisan postopek)
Quote:
Hey guys, I've got a 98 1.8T. I've had a k04 and chip for a while and wanted to get more performance. I was recommended to port and polish the intake and exhaust. We found out they used abrasive material to do it like gritty sand. So I got with my friend that tunes Hondas and we decided to try it ourselves. We got a bag of sandblasting sand and hooked up into the intake and started the car. We had to hold the gas so it would run. He wanted to let the engine suck in the sand through the intake so it would port it out and then push it out the ehxaust so it would port the exhaust manifold.
I was worried that it might cause problems but he figured it'd be OK as long as we didn't make boost and it get sucked in the turbo. After running the car and letting it suck in sand we got about half way through a 25 lb bag. The check engine light was on and the engine was bucking and kicking and sounding really weird. We stopped and hooked the car back up normal and took off the sand supply. We tried to start it again and it was really hard. Once started it couldn't idle and kept making weird noises. We took it out and drove it and it started to make scraping and knocking noises.
Help! Can anyone tell me what to do! My buddy only does Hondas so he doesn't know much about Audis.
hahahahha :rofl: :rofl:
alfa 166
Prispevkov: 512
Kraj: ljubljana
A mislite, da je čiščenje glavne lopute in odprtine preko katere gredo izpušni plini iz EGR ventila v sesalni kolektor ( se pravi čiščenje do tja kamor se pač doseže) brez efekta ( pri 2.4 mjet) ali bi se vseeno splačalo? In če mogoče kdo ve, koliko je dela z demontažo ses. kolektorja?
Lp, Mare
Killergame17
Prispevkov: 2988
Apophis napisal/-a:
to je res za crknit =D> :lol: bolj neumne stvari pa še ne..mašina čudne zvoke iz sebe spušča in čudno dela..frend sam na hondi to dela,na audije se pa ne spozna :lol: :lol: :loljeah: :rofl:
Alfa 164 3.0 V6 12V QV Q2
Alfa 156 SW 1.9 JTDm 16V 2005
http://www.alfa-parts.net
alfa 166 napisal/-a:A mislite, da je čiščenje glavne lopute in odprtine preko katere gredo izpušni plini iz EGR ventila v sesalni kolektor ( se pravi čiščenje do tja kamor se pač doseže) brez efekta ( pri 2.4 mjet) ali bi se vseeno splačalo? In če mogoče kdo ve, koliko je dela z demontažo ses. kolektorja?
Lp, Mare
Splača se spucat, sploh če je res fajn zasvinjano, pri moji sem napraskal ven cca 1 jogurnti lonček svinjarije in je bilo občutno boljše potem.
Sam pazi da ne boš svinjarije spravil v sesalni kolektor, ker veliki koščki ne morejo dobro vplivat na delovanje motorja če pridejo v cilinder in potem naprej v turbino...
Dela z demontažo kolektorja je ogromno, sam to bi se res splačalo naredit, pomojem... če ne drugače takrat ko menjaš glavne jermene, ker je treba jermen dol vzet načeloma...
spartan
Prispevkov: 629
Koliko pa misliš da je dela?
Tolk, da ko sem imel zadnjič pol sprednjega konca podrtega (ko sem popravljal cevi za moj "upgradean" intercooler) me je minilo ko sem videl kaj je treba vse dol pobrat.
Obstaja en trik da naj bi blokiral jermenico common rail pumpe z dvema vijakoma in na ta način lahko snel sesalni kolektor brez snemanja zobatega jermena, vendar je vseeno na sesalnem kolektorju miljon enih cevk in cevčic ki pojma nimam kaj bi naredil z njimi :D
Mogoče bi bilo bolj enostavno v avto zmonitrati "Water/methanol injection" in lepo počakati par tisoč kilometrov da se zadeva spuca (W/M deluje podobno kot visokotlačni čistilec, kapljice vode počasi odnesejo vso svinjarijo iz kolektorja čez mašino in ven...)
spartan
Prispevkov: 629
hmmm..."meth addiction" za dizel mašino.
Jah treba je šmarnico nekam stankat :>
Prispevkov: 7137
Ne vem zakaj, vendar tale zadnji postopek meni precej diši na tisto Honda/Audi portanje :lol: , le da se tu uporablja svinjarija iz sesalnega kolektorja. :|
Brez panike... Postopek nikakor ni "hiter", saj voda in metanol relativno počasi odstranjujeta svinjarijo in ni možnosti da bi karkoli poškodoval, poleg vsega pa večina te svinjarije (ki je mešanica saj in olja) v cilindru zgori, tako da ko pride iz cilindra ven ni šans da bi s tem kakorkoli poškodoval notranje dele motorja...
Da bi očistil povprečno zapacan kolektor bi verjetno rabil nekaj tisoč kilometrov vožnje.
Drugače pa zadeva blagodejno vpliva na delovanje motorja, saj niža temperaturo izpušnih plinov in pri dizlu pomaga pri bolj temeljitem izgorevanju (mikro eksplozije vodnih delcev pripomorejo k boljšemu mešanju znotraj cilindra...)
alfa 166
Prispevkov: 512
Kraj: ljubljana
Se pravi je edina varianta odmontirati kolektor in ga sčistiti, nobene bližnjice kot je na youtubu da ob prižganem motorju izprazniš spray v sesalni kolektor :D
Tudi to naj bi pomagalo, če imaš v spraju pravo sredstvo, samo to je bolj tak "kozolec tuning"...
