kakšnih težav z dpf?alfadoctor napisal/-a:Pozdravljeni Alfisti, olje se meri vedno pri hladnem motorju in še to zdaj pri novejših modelih mora olje segati malenkost pod max oznako, ker če je čez max oznako lahko pride do raznih težav z dpf filtrom.
Ena univerza v ZDA:"In the types of bearing surface contact we have looked at, we have seen no benefit. In some cases we have seen detrimental effect. The solids in the oil tend to accumulate at inlets and act as a dam, which simply blocks the oil from entering. Instead of helping, it is actually depriving parts of lubricant"
In defense of Slick 50, tests done on a Chevy 6 cylinder engine by the University of Utah Engineering Experiment Station found that after treatment with the PTFE additive the test engine's friction was reduced by 13.1 percent, the output horsepower increased from 5.3 percent to 8.1 percent, and fuel economy improved as well. Unfortunately, the same tests concluded that "There was a pressure drop across the oil filter resulting from possible clogging of small passageways." Oil analysis showed that iron contamination doubled after the treatment, indicating that engine wear increased!
NEALKOHOLIK pa NE! Po forumu brskajo: 0 registriranih uporabnikov in 4 gosti
