Tempomat ne deluje
al4x
Prispevkov: 57
Pridružen: To Jan 31, 2012 11:21 am
Izvedel in rezultat je:
Reading CAN configuration data ...
CAN CONFIGURATION DATA:
00 00 05 6B 00 00 05 6B 00 00 00 03 00 00 00 03 00 00 00 00
00 00 05 6B 00 00 05 09 00 00 05 6B 00 00 05 09 00 00 05 09
34 36 37 39 33 35 37 35 20 20 20 44 54 53 49 45 45 50 44 45 20 20 00 07 11 6B 05 00 00 09 05 00 00 11 00 00 82 06 00
CURRENTLY CONFIGURED CAN MODULES:
Body Computer Node (NBC)
Engine Control Node (NCM)
Dashboard Node (NQS)
Receiver Radio/Radio Navigator Node (NRR/RMN)
Brake System Node (NFR)
Driver Door Node (NPG)
Climate Control Node (NCL)
CURRENTLY AVAILABLE CAN MODULES:
CAN MODULES THAT REQUIRE EOL PROGRAMMING:
27.11.2012 12:21:22
CONNECTED TO:
ALFA 147 1.9 JTD
CAN Setup / PROXI Alignment Procedure
CURRENTLY CONFIGURED CAN MODULES::
Body Computer Node (NBC):
Engine Control Node (NCM):
Dashboard Node (NQS):
Receiver Radio/Radio Navigator Node (NRR/RMN):
Brake System Node (NFR):
Driver Door Node (NPG):
Climate Control Node (NCL):
CURRENTLY AVAILABLE CAN MODULES::
CAN MODULES THAT REQUIRE EOL PROGRAMMING::
WARNING: This vehicle is properly configured. PROXI Alignment is not needed!
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing CAN configuration data ...
Writing to module: Body Computer Node (NBC) SUCCESS!
0
0
0
0
0
0
Writing to module: Dashboard Node (NQS) FAILED! - Timeout error
Writing to module: Driver Door Node (NPG) SUCCESS!
Writing to module: Climate Control Node (NCL) SUCCESS!
FAILED TO EXECUTE
Kot vidiš imaš težave okoli povezave armaturne plošče na CAN omrežje:
... Zato tudi prisotna napaka c1521 v ABS centrali... in verjetno zato tudi ne dela tempomat.
al4x
Prispevkov: 57
Kaj bi to lahko bilo? O napaki c 1521 ni neko veliko napisanega
Pojma nimam... lahko da je napaka na kablih ali kaj podobnega.
al4x
Prispevkov: 57
Dashboard Node (NQS) so števci(potovalni rač, hitrost, obrati)? ali je kaj drugega?
Jap...
al4x
Prispevkov: 57
Malo premrzlo je sedaj, da bi razdrl vse :D pa še časa nimam.
Sedaj mi ne gre več v kategorijo Service(multiecuscan) ELM-ECU connection error #-o v motor gre normalno
Upam da bom imel več sreče jutri
če se menja števec je potrebno še kaj dodatno narest?
al4x
Prispevkov: 57
Berem neko temo na angleškem forumu, kjer je eden imel na 156 probleme z VDC in imel napaki
C 1520 - Can terminal -> bad connection
C 1521 - Can Terminal -> bad connection
in rešitev
today i remove the top end of the steering wheel and check the wiring with it's terminals and voala ,one jack was corrupted,now everything is fine,and without message: VDC System Failure
je možno kaj v vezi z tem?
al4x
Prispevkov: 57
današnje delo :
Zanima me ćemu sta tista dva konektorja označena spodaj:
Danes sem dobil samo airbag ven in nisem razkopaval dalje. Niti nevem katere terminale misli tisti iz angleškega foruma.
Prvo sem mislil dobiti števce ven, vendar je potrebno volan dol vzet :roll:
sofoiks
Prispevkov: 455
Zivjo si mogoce kaj pogruntal glede tega :)?
Q_4
Prispevkov: 2354
Vozilo: Alfa GT
Kraj: MB-Okolica
Če se ne motim sta modra 2 za multifunkcijo.
