Reading CAN configuration data ...
CAN CONFIGURATION DATA:
00 00 05 6B 00 00 05 6B 00 00 00 03 00 00 00 03 00 00 00 00
00 00 05 6B 00 00 05 09 00 00 05 6B 00 00 05 09 00 00 05 09
34 36 37 39 33 35 37 35 20 20 20 44 54 53 49 45 45 50 44 45 20 20 00 07 11 6B 05 00 00 09 05 00 00 11 00 00 82 06 00
CURRENTLY CONFIGURED CAN MODULES:
Body Computer Node (NBC)
Engine Control Node (NCM)
Dashboard Node (NQS)
Receiver Radio/Radio Navigator Node (NRR/RMN)
Brake System Node (NFR)
Driver Door Node (NPG)
Climate Control Node (NCL)
CURRENTLY AVAILABLE CAN MODULES:
CAN MODULES THAT REQUIRE EOL PROGRAMMING:
27.11.2012 12:21:22
CONNECTED TO:
ALFA 147 1.9 JTD
CAN Setup / PROXI Alignment Procedure
CURRENTLY CONFIGURED CAN MODULES::
Body Computer Node (NBC):
Engine Control Node (NCM):
Dashboard Node (NQS):
Receiver Radio/Radio Navigator Node (NRR/RMN):
Brake System Node (NFR):
Driver Door Node (NPG):
Climate Control Node (NCL):
CURRENTLY AVAILABLE CAN MODULES::
CAN MODULES THAT REQUIRE EOL PROGRAMMING::
WARNING: This vehicle is properly configured. PROXI Alignment is not needed!
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing CAN configuration data ...
Writing to module: Body Computer Node (NBC) SUCCESS!
0
0
0
0
0
0
Writing to module: Dashboard Node (NQS) FAILED! - Timeout error
Writing to module: Driver Door Node (NPG) SUCCESS!
Writing to module: Climate Control Node (NCL) SUCCESS!
FAILED TO EXECUTE
Malo premrzlo je sedaj, da bi razdrl vse pa še časa nimam.
Sedaj mi ne gre več v kategorijo Service(multiecuscan) ELM-ECU connection error v motor gre normalno
Upam da bom imel več sreče jutri
če se menja števec je potrebno še kaj dodatno narest?
Berem neko temo na angleškem forumu, kjer je eden imel na 156 probleme z VDC in imel napaki
C 1520 - Can terminal -> bad connection
C 1521 - Can Terminal -> bad connection
in rešitev
today i remove the top end of the steering wheel and check the wiring with it's terminals and voala ,one jack was corrupted,now everything is fine,and without message: VDC System Failure
Zanima me ćemu sta tista dva konektorja označena spodaj:
Danes sem dobil samo airbag ven in nisem razkopaval dalje. Niti nevem katere terminale misli tisti iz angleškega foruma.
Prvo sem mislil dobiti števce ven, vendar je potrebno volan dol vzet
