coolbits napisal/-a:Na fwd avtu se gume spredaj hitreje obrabljajo, ker je spredaj pogon, zavijanje in večina zaviranja.
Jaz pa zaradi več funkcij sprednjih koles raje dam nov par vedno spredaj in me neki "strokovnjaki" ne zanimajo preveč
Pa tud raje imam, da mi zadek malo odnese (če že mora) in ga ulovim, kot da izgubim oprijem na sprednjih in s tem možnost zavijanja.
Dejstvo je, da stroka ve več od samoklicanih strokovanjakov na forumu, ki jim je verjetno že OŠ fizika delala težave. Ljudje ki so leta študirali te stvari vejo nepredstavljivo več, saj so se leta učili fizike. Podobno kot zdravnik ve dosti dosti več o delovanju človeškega telesa kot bioenergetik.
Ti oz. vam bom dal razlago zakaj je boljše gume imeti zadaj - pa ne od naših voznikov varne vožnje, (pa tudi proizvajalci svetujejo med drugim enako).
Why New Front Tires on Your Back Wheels Are a Good Idea
Some tire stores insist on installing two new tires on the rear wheels of vehicles when the fronts are worn, and moving the old rear tires to the front--much to the dismay of many customers who want the new tires on the front. So, who's right?
Actually, I agree with the stores, as do the tire companies. Here's why: In dry, clear weather it really doesn't make much difference. But if the road is wet, the new, full-treaded tires are less likely to lose traction than the partly worn ones. If you're hauling ants down the road and come to a wet curve, the full-treaded tires on the rear will stay behind you, where they belong.
If the rear tires have less tread, there's a greater chance that they will slip, putting your rear bumper into the ditch. Okay, if the front tires skid, there's the chance you might go off the road, too--but at least it'll be headfirst, where your seatbelts and airbags offer more protection.
2. When replacing only two tires, the new ones go on the front.
The truth: Rear tires provide stability, and without stability, steering or braking on a wet or even damp surface might cause a spin. If you have new tires up front, they will easily disperse water while the half-worn rears will go surfing: The water will literally lift the worn rear tires off the road. If you're in a slight corner or on a crowned road, the car will spin out so fast you won't be able to say, "Oh, fudge!"
There is no "even if" to this one. Whether you own a front-, rear- or all-wheel-drive car, truck, or SUV, the tires with the most tread go on the rear. Don't believe it? Watch this.
Vir:
http://www.popularmechanics.com/cars/ho ... 9/4243992/" onclick="window.open(this.href);return false;
http://www.popularmechanics.com/cars/ho ... -10031440/" onclick="window.open(this.href);return false;
Pa še nasveti pri kupovanju gum:
http://www.popularmechanics.com/cars/ho ... s-9451125/" onclick="window.open(this.href);return false;
Če po tem še vedno vztrajaš pri svojem, si pač prever trmast, da sprejmeš dejstva in argumente in na podlagi tega oblikuješ svoje mnenje.
